Created this script to automate PWOL installation.
All instructions taken here:
Adjusted for Gl.iNet (as it uses nginx)
#!/bin/sh
mkdir -p /www/pwol
cat > /www/pwol/index.html << EOF
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="Cache-Control" content="no-cache, no-store, must-revalidate" />
<link rel="icon" type="image/png" href="/luci-static/bootstrap/favicon.png"/>
<title>Public Wake-On-LAN Interface</title>
<style>
body { text-align: center; }
table { border-collapse: collapse; }
th, td { padding: 1px 5px 1px 5px; border: 1px solid black; }
button { margin: 1px 2px 1px 2px; }
.red { color: #f00; }.blue { color: #00f; }.text-center { text-align: center }.w-100 { width: 100% }.w-80 { width: 80% }.elem-center { margin-left: auto; margin-right: auto; }
</style>
</head>
<body>
<h1>Public Wake-On-LAN Interface</h1>
<div id="err_cont" class="center red" hidden>error text</div>
<table id="dev_list" class="elem-center">
<tr><th>Hostname</th><th>MAC Addr</th><th>IP Addr</th><th>Status</th><th>Action</th></tr>
</table>
<script src="script.js"></script>
</body>
</html>
EOF
cat > /www/pwol/script.js << EOF
'use strict';
const {error} = console;
const devices = [];
const api_ep = "/cgi-bin/pwol-ctl";
const srr = "/luci-static/resources/";
Object.defineProperties(Date, { now_sec: { enumerable: true, get() { return (Date.now()/1000) >>> 0; }, } });
class NwkDevice {
// Class definition...
function api_get(req) { /* Function definition... */ };
function show_error(msg, err) { /* Function definition... */ };
function create_dev_table(resp) { /* Function definition... */ };
window.addEventListener('DOMContentLoaded', function main(evt) {
api_get({ cmd: "hl" }).then(create_dev_table).catch(show_error.bind(this, "ERROR: Failed to read states of devices"));
EOF
ln -s /www/pwol/api.lua /www/cgi-bin/pwol-ctl
cat > /www/pwol/api.lua << EOF
#!/usr/bin/lua
require("uci");
require("nixio");
require("luci.jsonc");
require("luci.http");
require("luci.ip");
local dev_list_path = "/www/pwol/dev_list.txt";
function contains(arr, val) /* Function definition... */ end;
function to_bool(val) /* Function definition... */ end;
function is_online(ip) /* Function definition... */ end;
function read_pub_hosts_list(file_path) /* Function definition... */ end;
local host_info = {}; -- Host information...
local host_ctl = {
['hl'] = function () /* Function definition... */ end,
['hs'] = function (host) /* Function definition... */ end,
['hw'] = function (host) /* Function definition... */ end,
local args = luci.http.urldecode_params(nixio.getenv('QUERY_STRING') or arg[1] or "cmd=hl");
local ret = {
['ok'] = false,
repeat
local public_hosts = read_pub_hosts_list(dev_list_path);
if (not public_hosts) then ret.err = "Failed reading list of available hosts"; break; end;
for k,v in pairs(uci.get_all('dhcp')) do
if (contains(public_hosts, v.name)) then host_info[v.name] = { mac = v.mac, ip = v.ip }; end;
end;
local cmd = host_ctl[args.cmd];
if (not cmd) then ret.err = "Unknown command"; break; end;
local data = cmd(args.host);
if (not data) then ret.err = "Unknown host"; break; end;
ret.ok = true;
ret.data = data;
until (true);
print("Status: 200 OK");
print("Content-type: application/json\n");
print(luci.jsonc.stringify(ret, '\t'));
EOF
touch /www/pwol/dev_list.txt
echo "PWOL setup completed."
