Hi. New here. I have a calyx internet that uses t mobile cell network. I'm getting poor upload speed. They just announced they support other routers as opposed to their proprietary Hotspot one they sent 3 years ago.
I get 2 or 3 bars . My download varies from 20 to 150. Upload varies from 1 to 10
The variability is the problem.
What router is best for me to get high upload performance
The network speed is mainly related to the operator's base station cover situation in the location..
In the same location, the antenna performance of the cellular router and the mobile phone is similar. Like, if the upload speed of the mobile phone is 1-10Mbps, the upload speed of the cellular router is likely to be within this range.
I think I can't determine if the cellular router is better than phone for you, but you can order a 5G cellular router to test if the following meets your needs.
