Select Wireguard server commad line
I wanted to select vpn connection command line from the below wireguard configuration. Default option works commandline without issues. but how can i select peer?
root@GL-SFT1200:~# cat /etc/config/wireguard
config proxy
option access ‘ACCEPT’
option main_server ‘vakkad-piwg1-5clients’
option enable ‘1’
option host ‘59.8.22.24’
config peers ‘wg_peer_461’
option name ‘omv2’
option address ‘10.13.13.3’
option listen_port ‘51820’
option private_key ‘ghfddhg’
option dns ‘10.13.13.1’
option end_point ‘ailwire.ddns.net:51820
option public_key ‘idafd=’
option allowed_ips ‘0.0.0.0/0’
option persistent_keepalive ‘25’
option preshared_key ‘fgsfdgd’
config peers ‘wg_peer_1794’
option name ‘vpnunlimited’
option dns ‘10.100.0.1’
option address ‘10.100.253.116/32’
option private_key ‘2dafdsfadafc=’
option end_point ‘162.218.95.14:15266’
option public_key ‘adfasfdsafdasf’
option preshared_key 'afdasf
hi,
You can select peer by replacing the main_server with the name of peer that you want to select.
for exampple:
   uci set wireguard.@proxy[0].main_server=vpnunlimited''
   uci commit wireguard
   /etc/init.d/wireguard restart
I’m not seeing a /etc/init.d/wireguard on firmware 4.4.6-release1 or 4.3.7-release4. Am I missing a script?
/etc/init.d/wireguard has been deleted on version 4.x.You can select peer with following commands.
uci set network.wgclient.config='peer_2002'
uci commit network
/etc/init.d/network restart
