Wrote following script for devices that cannot handle AdGuard Home or Pi-Hole.
Minimal requirements 20 MB of storage.
This script should just be run once and it will setup LuCI web interface automatically.
I will be very pleased if you will share your fixes or other information.
#!/bin/sh
FILTERING_PACKAGE="adblock"
UPDATE_SCRIPT="/usr/bin/adblock-update.sh"
AUTO_UPDATE_SCRIPT="/usr/bin/adblock-auto-update.sh"
if [ ! -d "/usr/local" ]; then
mkdir -p /usr/local/bin
fi
LUA_PACKAGES="lua luci-lib-jsonc"
is_lua_package_installed() {
local package=$1
if opkg list-installed | grep -q "^${package}$"; then
return 0
else
return 1
fi
install_lua_packages() {
for package in $LUA_PACKAGES; do
if ! is_lua_package_installed "$package"; then
echo "Installing ${package}..."
opkg update
opkg install "${package}"
else
echo "${package} is already installed."
fi
done
install_package() {
if ! opkg list-installed | grep -q "^${FILTERING_PACKAGE}$"; then
opkg update
opkg install "${FILTERING_PACKAGE}"
fi
enable_service() {
if ! /etc/init.d/"${FILTERING_PACKAGE}" enabled; then
fi
configure_package() {
uci set "${FILTERING_PACKAGE}".config.auto_update=0
uci set "${FILTERING_PACKAGE}".config.block_malware=0
uci set "${FILTERING_PACKAGE}".config.block_iploggers=0
uci set "${FILTERING_PACKAGE}".config.enable_adblock=0
uci commit "${FILTERING_PACKAGE}"
create_update_script() {
cat > "${UPDATE_SCRIPT}" << EOF
#!/bin/sh
URL="https://raw.githubusercontent.com/AdguardTeam/AdguardFilters/master/Filters/filter.txt"
MALWARE_URLS="https://raw.githubusercontent.com/DandelionSprout/adfilt/master/Alternate%20versions%20Anti-Malware%20List/AntiMalwareAdGuardHome.txt https://raw.githubusercontent.com/AdguardTeam/FiltersRegistry/master/filters/ThirdParty/filter_255_Phishing_URL_Blocklist/filter.txt https://raw.githubusercontent.com/AdguardTeam/FiltersRegistry/master/filters/ThirdParty/filter_256_Scam_Blocklist/filter.txt"
IPLOGGER_URL="https://raw.githubusercontent.com/Konnor88/anti-grabify/master/url_list.txt"
FILE="/etc/adblock/adblock.conf"
. /etc/uci-defaults/40-adblock
update_filter() {
if [ "\$(uci get ${FILTERING_PACKAGE}.config.auto_update)" = "1" ]; then
wget -O /tmp/filter.txt "\$URL"
sed -i '/^!/d' "\$FILE"
cat /tmp/filter.txt >> "\$FILE"
if [ "\$(uci get ${FILTERING_PACKAGE}.config.block_malware)" = "1" ]; then
for url in \$MALWARE_URLS; do
wget -O - "\$url" >> "\$FILE"
done
fi
if [ "\$(uci get ${FILTERING_PACKAGE}.config.block_iploggers)" = "1" ]; then
wget -O - "\$IPLOGGER_URL" >> "\$FILE"
fi
fi
restart_service() {
/etc/init.d/${FILTERING_PACKAGE} restart
update_filter
restart_service
EOF
chmod +x "${UPDATE_SCRIPT}"
create_auto_update_script() {
if ! /etc/init.d/cron enabled; then
/etc/init.d/cron start
fi
cat > "${AUTO_UPDATE_SCRIPT}" << EOF
#!/bin/sh
(crontab -l 2>/dev/null; echo "0 0 */5 * * /usr/bin/adblock-update.sh") | crontab -
else
(crontab -l | grep -v '/usr/bin/adblock-update.sh' || true) | crontab -
fi
EOF
chmod +x "${AUTO_UPDATE_SCRIPT}"
create_luci_interface() {
cat > "/usr/lib/lua/luci/controller/network_filtering.lua" << EOF
module("luci.controller.network_filtering", package.seeall)
function index()
entry({"admin", "network", "network_filtering"}, cbi("network_filtering"), _("Network filtering"))
end
EOF
cat > "/usr/lib/lua/luci/view/network_filtering/cbi.lua" << EOF
require "luci.util"
m = Map("adblock", translate("Network filtering"))
s = m:section(TypedSection, "adblock")
s.anonymous = true
btn = s:option(Button, "update", translate("Update"))
btn.inputtitle = translate("Update")
btn.inputstyle = "apply"
btn.write = function()
luci.sys.call("/usr/bin/adblock-update.sh")
luci.http.redirect(luci.dispatcher.build_url("admin", "network", "network_filtering"))
end
auto_update = s:option(Flag, "auto_update", translate("Auto Update"))
auto_update.default = 0
block_malware = s:option(Flag, "block_malware", translate("Block Malicious Websites"))
block_malware.default = 0
block_iploggers = s:option(Flag, "block_iploggers", translate("Block IP Loggers"))
block_iploggers.default = 0
enable_adblock = s:option(Flag, "enable_adblock", translate("Enable AdBlocking"))
enable_adblock.default = 0
return m
EOF
install_package
enable_service
configure_package
/etc/init.d/luci-module load network_filtering
/etc/init.d/luci-mod-admin restart
echo "Installation complete. Please configure the Network filtering settings through the LuCI web interface."
echo "This script is one-time use for installation. Manual updates can be performed through the GUI."
rm -- "$0"
exit 0
Uninstalling script:
#!/bin/sh
UPDATE_SCRIPT="/usr/bin/adblock-update.sh" # Changed to /usr/bin
AUTO_UPDATE_SCRIPT="/usr/bin/adblock-auto-update.sh" # Changed to /usr/bin
uninstall_package() {
if opkg list-installed | grep -q "^${FILTERING_PACKAGE}$"; then
opkg remove "${FILTERING_PACKAGE}"
fi
disable_service() {
if /etc/init.d/"${FILTERING_PACKAGE}" enabled; then
/etc/init.d/"${FILTERING_PACKAGE}" disable
fi
remove_update_script() {
if [ -f "${UPDATE_SCRIPT}" ]; then
rm "${UPDATE_SCRIPT}"
fi
remove_auto_update_script() {
if [ -f "${AUTO_UPDATE_SCRIPT}" ]; then
rm "${AUTO_UPDATE_SCRIPT}"
fi
remove_luci_interface() {
rm -f "/usr/lib/lua/luci/controller/network_filtering.lua"
rm -f "/usr/lib/lua/luci/view/network_filtering/cbi.lua"
remove_cron_jobs() {
crontab -l | grep -v '/usr/bin/adblock-update.sh' | crontab -
remove_unused_dependencies() {
opkg autoremove
echo "Starting Network Filtering uninstallation..."
uninstall_package
disable_service
remove_cron_jobs
remove_unused_dependencies # Added step to remove unused dependencies
echo "Uninstallation complete. Network Filtering has been removed."
rm -- "$0"
exit 0
