Which works on theAXT1800, but is much harder to use than the stock firmware.
Problem is that the u-boot failsafe (did it change it?) times out when uploading large images (such as stock firmware).
Even after uploading your uboot.html from here Commits · gl-inet/uboot-ipq60xx · GitHub I still have problem—I can upload the firmware I built as it is only 8 MB, but the stock firmware always fails to upload.
I really want a 64-bit kernel (32-bit user-space is fine) to work with, but I also want stock firmware (with all the gl-inet interface stuff which is polished especially with wireguard), and would prefer 32-bit stock firmware to nothing.
While glinet image use seperate mtd partitions for squashfs, kernel, and ubi—this 64-bit build uses one mtd partition for the three and 3 ubi partitions.
I figured out what the problem was with uploading.
The vanilla openwrt used the same ip address, and I had firefox on auto-refresh in another tab, and the u-boot uhttpd couldn’t handle the multi-tasking of the spurious requests (I DoSed myself).
