Send Email when going to WAN Backup
I want to send an Email when the Router is going from WAN to Cellular or Tethering WAN Backup.
Is this possible? I installed Postfix, but dont know how to start and realize that.
In the UI I did not find anything about that.
Cheers
Carsten
Please try the GL GoodCloud Platform, support the Email notice for the WAN interface down/up.
Hi Bruce,
I think that only shows wheter the Router is online or offline and not if he is using WAN Backup G5 or LAN ISP?
Cheers Carsten
It can also send a reminder email when a device switches WAN (Mutil-WAN). Since if the WAN switch is triggered, so the device must have a brief up/down in the WAN switch.
Note: The device switches the network very quickly. For the connection between the device and the cloud platform, it is a quick offline and online. In this case, if the platform enables notification feature(email) about the device online and offline, the time interval between the two emails will be very short. The order of email arrival is subject to change.
My good cloud interface is different and does not have the WAN option, is this normal?
My region is Europe
It has.
Choose your device and then:
exactly, but not LAN status and WAN status!
Since WAN loss will cause disconnection from GoodCloud this will be the option you need for tracking it down.
The notifications don't contain the IP, WAN ID/device, etc - so it's nice I can use this to get notified when on/offline, but I'd love to know which connection I am rolling to each time (and the option for more than one notification).
