I have downloaded the Astrill openvpn profiles, upload to the MiFi, running many times the route always give me the message, it cant working, could someone look at this issues, otherwise, Please not say the router support Astrill!
following the system log:
Wed Dec 18 02:34:47 2019 daemon.notice openvpn[23671]: OpenVPN 2.4.5 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Dec 18 02:34:47 2019 daemon.notice openvpn[23671]: library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.10
Wed Dec 18 02:34:47 2019 daemon.warn openvpn[23681]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Dec 18 02:34:47 2019 daemon.warn openvpn[23681]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Dec 18 02:34:47 2019 daemon.notice openvpn[23681]: Outgoing Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:34:47 2019 daemon.notice openvpn[23681]: Incoming Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:34:47 2019 daemon.warn openvpn[23681]: WARNING: normally if you use --mssfix and/or --fragment, you should also set --tun-mtu 1500 (currently it is 1296)
Wed Dec 18 02:34:47 2019 daemon.notice openvpn[23681]: TCP/UDP: Preserving recently used remote address: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:34:47 2019 daemon.notice openvpn[23681]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Wed Dec 18 02:34:47 2019 daemon.notice openvpn[23681]: UDP link local: (not bound)
Wed Dec 18 02:34:47 2019 daemon.notice openvpn[23681]: UDP link remote: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:35:47 2019 daemon.err openvpn[23681]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Dec 18 02:35:47 2019 daemon.err openvpn[23681]: TLS Error: TLS handshake failed
Wed Dec 18 02:35:47 2019 daemon.notice openvpn[23681]: SIGHUP[soft,tls-error] received, process restarting
Wed Dec 18 02:35:47 2019 daemon.warn openvpn[23681]: DEPRECATED OPTION: --max-routes option ignored.The number of routes is unlimited as of OpenVPN 2.4. This option will be removed in a future version, please remove it from your configuration.
Wed Dec 18 02:35:47 2019 daemon.warn openvpn[23681]: Unrecognized option or missing or extra parameter(s) in /etc/openvpn/ovpn2/UDP-Taiwan.ovpn:24: block-outside-dns (2.4.5)
Wed Dec 18 02:35:49 2019 daemon.notice openvpn[23681]: OpenVPN 2.4.5 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Dec 18 02:35:49 2019 daemon.notice openvpn[23681]: library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.10
Wed Dec 18 02:35:49 2019 daemon.notice openvpn[23681]: Restart pause, 5 second(s)
Wed Dec 18 02:35:54 2019 daemon.warn openvpn[23681]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Dec 18 02:35:54 2019 daemon.warn openvpn[23681]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Dec 18 02:35:54 2019 daemon.notice openvpn[23681]: Outgoing Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:35:54 2019 daemon.notice openvpn[23681]: Incoming Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:35:54 2019 daemon.warn openvpn[23681]: WARNING: normally if you use --mssfix and/or --fragment, you should also set --tun-mtu 1500 (currently it is 1296)
Wed Dec 18 02:35:54 2019 daemon.notice openvpn[23681]: TCP/UDP: Preserving recently used remote address: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:35:54 2019 daemon.notice openvpn[23681]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Wed Dec 18 02:35:54 2019 daemon.notice openvpn[23681]: UDP link local: (not bound)
Wed Dec 18 02:35:54 2019 daemon.notice openvpn[23681]: UDP link remote: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:36:54 2019 daemon.err openvpn[23681]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Dec 18 02:36:54 2019 daemon.err openvpn[23681]: TLS Error: TLS handshake failed
Wed Dec 18 02:36:54 2019 daemon.notice openvpn[23681]: SIGHUP[soft,tls-error] received, process restarting
Wed Dec 18 02:36:55 2019 daemon.warn openvpn[23681]: DEPRECATED OPTION: --max-routes option ignored.The number of routes is unlimited as of OpenVPN 2.4. This option will be removed in a future version, please remove it from your configuration.
Wed Dec 18 02:36:55 2019 daemon.warn openvpn[23681]: Unrecognized option or missing or extra parameter(s) in /etc/openvpn/ovpn2/UDP-Taiwan.ovpn:24: block-outside-dns (2.4.5)
Wed Dec 18 02:36:55 2019 daemon.notice openvpn[23681]: OpenVPN 2.4.5 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Dec 18 02:36:55 2019 daemon.notice openvpn[23681]: library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.10
Wed Dec 18 02:36:55 2019 daemon.notice openvpn[23681]: Restart pause, 5 second(s)
Wed Dec 18 02:37:00 2019 daemon.warn openvpn[23681]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Dec 18 02:37:00 2019 daemon.warn openvpn[23681]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Dec 18 02:37:00 2019 daemon.notice openvpn[23681]: Outgoing Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:37:00 2019 daemon.notice openvpn[23681]: Incoming Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:37:00 2019 daemon.warn openvpn[23681]: WARNING: normally if you use --mssfix and/or --fragment, you should also set --tun-mtu 1500 (currently it is 1296)
Wed Dec 18 02:37:00 2019 daemon.notice openvpn[23681]: TCP/UDP: Preserving recently used remote address: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:37:00 2019 daemon.notice openvpn[23681]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Wed Dec 18 02:37:00 2019 daemon.notice openvpn[23681]: UDP link local: (not bound)
Wed Dec 18 02:37:00 2019 daemon.notice openvpn[23681]: UDP link remote: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:37:16 2019 user.info : 1334: gl-vpn-client>> Stop, vpnpath=/etc/openvpn/ovpn2, serverfile=UDP-Taiwan.ovpn
Wed Dec 18 02:37:19 2019 daemon.info dnsmasq[23246]: exiting on receipt of SIGTERM
Wed Dec 18 02:37:22 2019 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Wed Dec 18 02:37:22 2019 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Wed Dec 18 02:37:23 2019 user.info : 1334: gl-vpn-client>> Start, vpnpath=/etc/openvpn/ovpn2, serverfile=UDP-Taiwan.ovpn
Wed Dec 18 02:37:23 2019 user.info : 1390: gl-vpn-client>> glconfig.openvpn.ovpn=/etc/openvpn/ovpn2/UDP-Taiwan.ovpn, glconfig.openvpn.clientid=ovpn2
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: started, version 2.80test2 cachesize 150
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: DNS service limited to local subnets
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq-dhcp[28678]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: using local addresses only for domain test
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: using local addresses only for domain onion
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: using local addresses only for domain localhost
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: using local addresses only for domain invalid
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: using local addresses only for domain bind
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: using nameserver 8.8.4.4#53
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: using nameserver 8.8.8.8#53
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: using local addresses only for domain lan
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: read /etc/hosts - 4 addresses
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: read /tmp/hosts/odhcpd - 0 addresses
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq[28678]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Dec 18 02:37:25 2019 daemon.info dnsmasq-dhcp[28678]: read /etc/ethers - 0 addresses
Wed Dec 18 02:37:38 2019 daemon.notice hostapd: wlan0: STA 80:00:0b:0c:79:02 IEEE 802.11: did not acknowledge authentication response
Wed Dec 18 02:37:38 2019 daemon.info hostapd: wlan0: STA 80:00:0b:0c:79:02 IEEE 802.11: authenticated
Wed Dec 18 02:37:38 2019 daemon.info hostapd: wlan0: STA 80:00:0b:0c:79:02 IEEE 802.11: associated (aid 2)
Wed Dec 18 02:37:38 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 80:00:0b:0c:79:02
Wed Dec 18 02:37:38 2019 daemon.info hostapd: wlan0: STA 80:00:0b:0c:79:02 RADIUS: starting accounting session 8D04BB560E7A9E9C
Wed Dec 18 02:37:38 2019 daemon.info hostapd: wlan0: STA 80:00:0b:0c:79:02 WPA: pairwise key handshake completed (RSN)
Wed Dec 18 02:37:47 2019 daemon.info dnsmasq[28678]: exiting on receipt of SIGTERM
Wed Dec 18 02:37:47 2019 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Wed Dec 18 02:37:47 2019 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: started, version 2.80test2 cachesize 150
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: DNS service limited to local subnets
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq-dhcp[29545]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: using local addresses only for domain test
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: using local addresses only for domain onion
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: using local addresses only for domain localhost
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: using local addresses only for domain invalid
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: using local addresses only for domain bind
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: using nameserver 8.8.4.4#53
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: using nameserver 8.8.8.8#53
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: using local addresses only for domain lan
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: read /etc/hosts - 4 addresses
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: read /tmp/hosts/odhcpd - 0 addresses
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq[29545]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Dec 18 02:37:49 2019 daemon.info dnsmasq-dhcp[29545]: read /etc/ethers - 0 addresses
Wed Dec 18 02:37:55 2019 daemon.notice openvpn[29784]: OpenVPN 2.4.5 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Dec 18 02:37:55 2019 daemon.notice openvpn[29784]: library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.10
Wed Dec 18 02:37:55 2019 daemon.warn openvpn[29864]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Dec 18 02:37:55 2019 daemon.warn openvpn[29864]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Dec 18 02:37:55 2019 daemon.notice openvpn[29864]: Outgoing Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:37:55 2019 daemon.notice openvpn[29864]: Incoming Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:37:55 2019 daemon.warn openvpn[29864]: WARNING: normally if you use --mssfix and/or --fragment, you should also set --tun-mtu 1500 (currently it is 1296)
Wed Dec 18 02:37:55 2019 daemon.notice openvpn[29864]: TCP/UDP: Preserving recently used remote address: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:37:55 2019 daemon.notice openvpn[29864]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Wed Dec 18 02:37:55 2019 daemon.notice openvpn[29864]: UDP link local: (not bound)
Wed Dec 18 02:37:55 2019 daemon.notice openvpn[29864]: UDP link remote: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:37:58 2019 daemon.info dnsmasq-dhcp[29545]: DHCPINFORM(br-lan) 192.168.8.200 80:00:0b:0c:79:02
Wed Dec 18 02:37:58 2019 daemon.info dnsmasq-dhcp[29545]: DHCPACK(br-lan) 192.168.8.200 80:00:0b:0c:79:02 Sonny-650
Wed Dec 18 02:38:03 2019 user.info : 1334: gl-vpn-client>> Start, vpnpath=/etc/openvpn/ovpn2, serverfile=UDP-Taiwan.ovpn
Wed Dec 18 02:38:03 2019 user.info : 1390: gl-vpn-client>> glconfig.openvpn.ovpn=/etc/openvpn/ovpn2/UDP-Taiwan.ovpn, glconfig.openvpn.clientid=ovpn2
Wed Dec 18 02:38:14 2019 user.debug : devices=null
Wed Dec 18 02:38:20 2019 user.debug : devices=null
Wed Dec 18 02:38:27 2019 user.info : 1334: gl-vpn-client>> Start, vpnpath=/etc/openvpn/ovpn2, serverfile=UDP-Taiwan.ovpn
Wed Dec 18 02:38:28 2019 user.info : 1390: gl-vpn-client>> glconfig.openvpn.ovpn=/etc/openvpn/ovpn2/UDP-Taiwan.ovpn, glconfig.openvpn.clientid=ovpn2
Wed Dec 18 02:38:37 2019 daemon.info dnsmasq-dhcp[29545]: DHCPINFORM(br-lan) 192.168.8.200 80:00:0b:0c:79:02
Wed Dec 18 02:38:37 2019 daemon.info dnsmasq-dhcp[29545]: DHCPACK(br-lan) 192.168.8.200 80:00:0b:0c:79:02 Sonny-650
Wed Dec 18 02:38:38 2019 daemon.info dnsmasq[29545]: exiting on receipt of SIGTERM
Wed Dec 18 02:38:39 2019 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Wed Dec 18 02:38:39 2019 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: started, version 2.80test2 cachesize 150
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: DNS service limited to local subnets
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq-dhcp[31428]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: using local addresses only for domain test
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: using local addresses only for domain onion
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: using local addresses only for domain localhost
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: using local addresses only for domain invalid
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: using local addresses only for domain bind
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: using nameserver 8.8.4.4#53
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: using nameserver 8.8.8.8#53
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: using local addresses only for domain lan
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: read /etc/hosts - 4 addresses
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: read /tmp/hosts/odhcpd - 0 addresses
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq[31428]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Dec 18 02:38:41 2019 daemon.info dnsmasq-dhcp[31428]: read /etc/ethers - 0 addresses
Wed Dec 18 02:38:55 2019 daemon.notice openvpn[31972]: OpenVPN 2.4.5 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Dec 18 02:38:55 2019 daemon.notice openvpn[31972]: library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.10
Wed Dec 18 02:38:55 2019 daemon.warn openvpn[31995]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Dec 18 02:38:55 2019 daemon.warn openvpn[31995]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Dec 18 02:38:55 2019 daemon.notice openvpn[31995]: Outgoing Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:38:55 2019 daemon.notice openvpn[31995]: Incoming Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:38:55 2019 daemon.warn openvpn[31995]: WARNING: normally if you use --mssfix and/or --fragment, you should also set --tun-mtu 1500 (currently it is 1296)
Wed Dec 18 02:38:55 2019 daemon.notice openvpn[31995]: TCP/UDP: Preserving recently used remote address: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:38:55 2019 daemon.notice openvpn[31995]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Wed Dec 18 02:38:55 2019 daemon.notice openvpn[31995]: UDP link local: (not bound)
Wed Dec 18 02:38:55 2019 daemon.notice openvpn[31995]: UDP link remote: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:38:57 2019 daemon.info dnsmasq[31428]: exiting on receipt of SIGTERM
Wed Dec 18 02:38:57 2019 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Wed Dec 18 02:38:57 2019 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: started, version 2.80test2 cachesize 150
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: DNS service limited to local subnets
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq-dhcp[32121]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: using local addresses only for domain test
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: using local addresses only for domain onion
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: using local addresses only for domain localhost
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: using local addresses only for domain invalid
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: using local addresses only for domain bind
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: using nameserver 8.8.4.4#53
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: using nameserver 8.8.8.8#53
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: using local addresses only for domain lan
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: read /etc/hosts - 4 addresses
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: read /tmp/hosts/odhcpd - 0 addresses
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq[32121]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Dec 18 02:38:59 2019 daemon.info dnsmasq-dhcp[32121]: read /etc/ethers - 0 addresses
Wed Dec 18 02:39:02 2019 daemon.info dnsmasq-dhcp[32121]: DHCPINFORM(br-lan) 192.168.8.200 80:00:0b:0c:79:02
Wed Dec 18 02:39:02 2019 daemon.info dnsmasq-dhcp[32121]: DHCPACK(br-lan) 192.168.8.200 80:00:0b:0c:79:02 Sonny-650
Wed Dec 18 02:39:09 2019 daemon.notice openvpn[32646]: OpenVPN 2.4.5 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Dec 18 02:39:09 2019 daemon.notice openvpn[32646]: library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.10
Wed Dec 18 02:39:09 2019 daemon.warn openvpn[32662]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Dec 18 02:39:09 2019 daemon.warn openvpn[32662]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Dec 18 02:39:10 2019 daemon.notice openvpn[32662]: Outgoing Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:39:10 2019 daemon.notice openvpn[32662]: Incoming Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:39:10 2019 daemon.warn openvpn[32662]: WARNING: normally if you use --mssfix and/or --fragment, you should also set --tun-mtu 1500 (currently it is 1296)
Wed Dec 18 02:39:10 2019 daemon.notice openvpn[32662]: TCP/UDP: Preserving recently used remote address: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:39:10 2019 daemon.notice openvpn[32662]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Wed Dec 18 02:39:10 2019 daemon.notice openvpn[32662]: UDP link local: (not bound)
Wed Dec 18 02:39:10 2019 daemon.notice openvpn[32662]: UDP link remote: [AF_INET]60.249.94.202:8292
Wed Dec 18 02:39:10 2019 daemon.info dnsmasq-dhcp[32121]: DHCPINFORM(br-lan) 192.168.8.200 80:00:0b:0c:79:02
Wed Dec 18 02:39:10 2019 daemon.info dnsmasq-dhcp[32121]: DHCPACK(br-lan) 192.168.8.200 80:00:0b:0c:79:02 Sonny-650
Wed Dec 18 02:39:49 2019 daemon.info dnsmasq-dhcp[32121]: DHCPINFORM(br-lan) 192.168.8.200 80:00:0b:0c:79:02
Wed Dec 18 02:39:49 2019 daemon.info dnsmasq-dhcp[32121]: DHCPACK(br-lan) 192.168.8.200 80:00:0b:0c:79:02 Sonny-650
Wed Dec 18 02:39:49 2019 user.info : 1334: gl-vpn-client>> Stop, vpnpath=/etc/openvpn/ovpn2, serverfile=UDP-Taiwan.ovpn
Wed Dec 18 02:39:52 2019 daemon.info dnsmasq[32121]: exiting on receipt of SIGTERM
Wed Dec 18 02:39:53 2019 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Wed Dec 18 02:39:53 2019 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: started, version 2.80test2 cachesize 150
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: DNS service limited to local subnets
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq-dhcp[1819]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: using local addresses only for domain test
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: using local addresses only for domain onion
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: using local addresses only for domain localhost
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: using local addresses only for domain invalid
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: using local addresses only for domain bind
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: using nameserver 8.8.4.4#53
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: using nameserver 8.8.8.8#53
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: using local addresses only for domain lan
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: read /etc/hosts - 4 addresses
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: read /tmp/hosts/odhcpd - 0 addresses
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq[1819]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Dec 18 02:39:56 2019 daemon.info dnsmasq-dhcp[1819]: read /etc/ethers - 0 addresses
Wed Dec 18 02:40:00 2019 user.info : 1334: gl-vpn-client>> Start, vpnpath=/etc/openvpn/ovpn3, serverfile=TCP-Taiwan.ovpn
Wed Dec 18 02:40:00 2019 user.info : 1390: gl-vpn-client>> glconfig.openvpn.ovpn=/etc/openvpn/ovpn3/TCP-Taiwan.ovpn, glconfig.openvpn.clientid=ovpn3
Wed Dec 18 02:40:06 2019 daemon.info dnsmasq[1819]: exiting on receipt of SIGTERM
Wed Dec 18 02:40:06 2019 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Wed Dec 18 02:40:06 2019 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: started, version 2.80test2 cachesize 150
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: DNS service limited to local subnets
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq-dhcp[2413]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: using local addresses only for domain test
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: using local addresses only for domain onion
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: using local addresses only for domain localhost
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: using local addresses only for domain invalid
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: using local addresses only for domain bind
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: using nameserver 8.8.4.4#53
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: using nameserver 8.8.8.8#53
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: using local addresses only for domain lan
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: read /etc/hosts - 4 addresses
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: read /tmp/hosts/odhcpd - 0 addresses
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq[2413]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Dec 18 02:40:07 2019 daemon.info dnsmasq-dhcp[2413]: read /etc/ethers - 0 addresses
Wed Dec 18 02:40:14 2019 daemon.notice openvpn[2640]: OpenVPN 2.4.5 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Dec 18 02:40:14 2019 daemon.notice openvpn[2640]: library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.10
Wed Dec 18 02:40:14 2019 daemon.warn openvpn[2713]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Dec 18 02:40:14 2019 daemon.warn openvpn[2713]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Dec 18 02:40:14 2019 daemon.notice openvpn[2713]: Outgoing Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:40:14 2019 daemon.notice openvpn[2713]: Incoming Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:40:14 2019 daemon.notice openvpn[2713]: TCP/UDP: Preserving recently used remote address: [AF_INET]60.249.94.202:443
Wed Dec 18 02:40:14 2019 daemon.notice openvpn[2713]: Socket Buffers: R=[87380->87380] S=[16384->16384]
Wed Dec 18 02:40:14 2019 daemon.notice openvpn[2713]: Attempting to establish TCP connection with [AF_INET]60.249.94.202:443 [nonblock]
Wed Dec 18 02:40:18 2019 daemon.info dnsmasq-dhcp[2413]: DHCPINFORM(br-lan) 192.168.8.200 80:00:0b:0c:79:02
Wed Dec 18 02:40:18 2019 daemon.info dnsmasq-dhcp[2413]: DHCPACK(br-lan) 192.168.8.200 80:00:0b:0c:79:02 Sonny-650
Wed Dec 18 02:41:01 2019 daemon.info dnsmasq-dhcp[2413]: DHCPINFORM(br-lan) 192.168.8.200 80:00:0b:0c:79:02
Wed Dec 18 02:41:01 2019 daemon.info dnsmasq-dhcp[2413]: DHCPACK(br-lan) 192.168.8.200 80:00:0b:0c:79:02 Sonny-650
Wed Dec 18 02:42:14 2019 daemon.err openvpn[2713]: TCP: connect to [AF_INET]60.249.94.202:443 failed: Operation timed out
Wed Dec 18 02:42:14 2019 daemon.notice openvpn[2713]: SIGHUP[connection failed(soft),init_instance] received, process restarting
Wed Dec 18 02:42:14 2019 daemon.warn openvpn[2713]: DEPRECATED OPTION: --max-routes option ignored.The number of routes is unlimited as of OpenVPN 2.4. This option will be removed in a future version, please remove it from your configuration.
Wed Dec 18 02:42:14 2019 daemon.warn openvpn[2713]: Unrecognized option or missing or extra parameter(s) in /etc/openvpn/ovpn3/TCP-Taiwan.ovpn:22: block-outside-dns (2.4.5)
Wed Dec 18 02:42:15 2019 daemon.notice openvpn[2713]: OpenVPN 2.4.5 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Dec 18 02:42:15 2019 daemon.notice openvpn[2713]: library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.10
Wed Dec 18 02:42:15 2019 daemon.notice openvpn[2713]: Restart pause, 2 second(s)
Wed Dec 18 02:42:17 2019 daemon.warn openvpn[2713]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Dec 18 02:42:17 2019 daemon.warn openvpn[2713]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Dec 18 02:42:17 2019 daemon.notice openvpn[2713]: Outgoing Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:42:17 2019 daemon.notice openvpn[2713]: Incoming Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Dec 18 02:42:17 2019 daemon.notice openvpn[2713]: TCP/UDP: Preserving recently used remote address: [AF_INET]60.249.94.202:443
Wed Dec 18 02:42:17 2019 daemon.notice openvpn[2713]: Socket Buffers: R=[87380->87380] S=[16384->16384]
Wed Dec 18 02:42:17 2019 daemon.notice openvpn[2713]: Attempting to establish TCP connection with [AF_INET]60.249.94.202:443 [nonblock]
