VPN-Router: Glinet Router GL-MT300N-V2
- Firmware: 3.211 based on OpenWrt 19.07.8
Client: Raspberry Pi 2 Model B Rev 1.1 with dyndns ( ddclient)
Hello Folks,
Im running an Server Component Sucessfully with the openvpn Protocol through my RAS.
But if i change the protocol to wg, no connection from outside isnt possible anymore.
I tried several vpn Provider, but on any is still the same with wg its not possible to get an connection from outside and with the same ones everything works fine over openvpn.
Iām using the glinet interface to run the wireguard client.
But i also use luci for making customized port forwardings rules.
iptables -A INPUT -i tun0 -p tcp --dport 51813 -m state --state NEW,ESTABLISHED -j ACCEPT
iptables -A OUTPUT -o tun0 -p tcp --dport 51813 -m state --state NEW,ESTABLISHED -j ACCEPT
iptables -A INPUT -i tun0 -p udp --dport 51813 -m state --state NEW,ESTABLISHED -j ACCEPT
iptables -A OUTPUT -o tun0 -p udp --dport 51813 -m state --state NEW,ESTABLISHED -j ACCEPT
iptables -I FORWARD -i tun0 -p udp -d 192.168.2.12 --dport 51813 -j ACCEPT
iptables -I FORWARD -i tun0 -p tcp -d 192.168.2.12 --dport 51813 -j ACCEPT
iptables -t nat -I PREROUTING -i tun0 -p tcp --dport 51813 -j DNAT --to-destination 192.168.2.12:45345
iptables -t nat -I PREROUTING -i tun0 -p udp --dport 51813 -j DNAT --to-destination 192.168.2.12:45345
iptables -t nat -A PREROUTING -i tun -p udp --dport 51813 -j REDIRECT --to-ports 45345
Here is my network.file:
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fdae:5c56:dd97::/48'
config interface 'lan'
option type 'bridge'
option ifname 'eth0.1'
option ip6assign '60'
option hostname 'GL-MT300N-V2-45f'
option ipaddr '192.168.8.1'
config interface 'wan'
option ifname 'eth0.2'
option proto 'dhcp'
option metric '10'
option ipv6 '0'
config interface 'wan6'
option proto 'dhcpv6'
option disabled '1'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '1 6t'
config switch_vlan
option vlan '2'
option ports '0 6t'
config interface 'guest'
option ifname 'guest'
option ipaddr '192.168.9.1'
config device 'wan_dev'
option name 'eth0.2'
option macaddr 'e4:95:6e:46:64:5f'
config device 'lan_dev'
option name 'eth0.1'
option macaddr 'e4:95:6e:46:64:60'
and my mwan3:
option enabled '1'
option mmx_mask '0x3F00'
option enabled '1'
list track_ip '8.8.4.4'
list track_ip '8.8.8.8'
list track_ip '208.67.222.222'
list track_ip '208.67.220.220'
option family 'ipv4'
option reliability '2'
option count '1'
option timeout '2'
option interval '5'
option down '3'
option up '8'
config interface 'wwan'
option enabled '1'
option count '1'
option timeout '2'
option interval '5'
option down '3'
option up '8'
config interface 'tethering'
option enabled '1'
option count '1'
option timeout '2'
option interval '5'
option down '3'
option up '8'
config interface 'modem_1_1'
option enabled '1'
option count '1'
option timeout '2'
option interval '5'
option down '3'
option up '8'
config member 'wan_only'
option interface 'wan'
option metric '1'
option weight '3'
config member 'wwan_only'
option interface 'wwan'
option metric '2'
option weight '3'
config member 'tethering_only'
option interface 'tethering'
option metric '3'
option weight '3'
config member 'modem_1_1_only'
option interface 'modem_1_1'
option metric '4'
option weight '3'
config policy 'default_poli'
list use_member 'wan_only'
list use_member 'wwan_only'
list use_member 'tethering_only'
list use_member 'modem_1_1_only'
option last_resort 'default'
config rule 'default_rule'
option dest_ip '0.0.0.0/0'
option use_policy 'default_poli'
All, other Rules are at least Defaults and not modified from myself.
But honestly im not really confident about how files is should post here to create an clear overview about my constellation.
Best regards
