Set duckdns URL as endpoint in Brume Wireguard Server
Hello everyone,
I’ve configured my Brume 2 behind my Fritzbox, and everything is functioning as expected.
Since my Fritzbox has a dynamic public IPv4 address from my ISP, there’s a possibility that the IP may change at some point.
To address this, I’ve set up DuckDNS with my Fritzbox’s IP. From what I understand, DuckDNS will attempt to synchronize with the Router IP automatically.
However, I couldn’t find any option in my Brume 2 interface where I can set the DuckDNS URL as the connection endpoint.
Can I simply set my DuckDNS URL as an endpoint in my configuration, like so: xxx.duckdns.org:58120, instead of my router IP? So it will always try to use the latest IP address?
I don’t use wireguard but I think you can use it as long as it resolves to yoyr public ip.
Just ping that use and see if it gives your public ip before putting it in the configuration.
I agree with this, the duckdns resolves and works correctly but the client profile created from the router only has the option to use WAN IP or the DDNS provided by glddns.com.
It would be good to have the option to override the Endpoint to include our own duckdns.org domain if required.
Also it would be good to give a default DNS other than 64.6.64.6
You can always change the config as you like, it’s plain text.
Since GLDDNS is the default DynDNS service of GL it makes sense that it’s the one which gets used.
Agree on edit config, it's easy to do.
To make life simpler it would be good to have configurable defaults like Endpoint over-ride and DNS over-ride. Then we can simply configure client via QR and camera.
Still don't understand why 64.6.64.6 is set as default without any option to override, just add a text box defaulting to 64.6.64.6 with option to set another default DNS IP.
it could be possible to add a service to use duckdns and the GLDDNS at the same time?
I'm just thinking about a plan B, after the GLinet DDNS issue.
There are already two profile, one for IPV4 and another one for IPV6.
Let me know what do you think, I don't want to brake everything!
No problem for my request, I was able to add duckdns and now I can use both DDNS, the GlInet and the DuckDns.
