agh620
January 18, 2019, 7:16pm
#1
hello everyone
can i set shadowsocks server in “GL.iNet GL-MT300N-V2 Mini Travel Router”? and how?
Is the Shadowsocks feature limited to gl-ar750 routers? or all of gl-inet routers can connect to shadowsocks?
can i set ssh proxy in “GL.iNet GL-MT300N-V2 Mini Travel Router”? and how?
agh620
January 18, 2019, 8:30pm
#2
i need openvpn , ssh proxy , shadowsocks at a router
but my budget is only 20 $
lostdog
January 18, 2019, 9:17pm
#3
See in the Advanced options if you can manually set up shadowsocks. I was using the AR-300M and had both Shadowsocks and OpenVPN running. You should look in to Wireguard. Much nicer than shadowsocks.
agh620
January 19, 2019, 5:40am
#4
lostdog
is your router (AR-300M) have Wireguard feature??
and plz send the exact link to buy your router (AR-300M) from amazon
and if it possible , plz send shot from shadowsocks, openvpn, Wireguard of your router
GL-MT300N-V2 can set Shadowsocks server or client, Overview - GL.iNet Docs
and also WireGuard server or client, WireGuard Client - GL.iNet Docs
agh620
January 19, 2019, 6:05am
#7
can you send me some shot from GL-MT300N-V2 shadowsocks and WireGuard?
What do you mean “shot” here?
Check the url I reply above, there are screenshots you need.
agh620
January 19, 2019, 10:35am
#11
but i googled “GL-MT300N-V2 frimware” and found that frimware version of GL-MT300N-V2 isn’t v3.0
the version written in your url tutrial is v3.0
