Hi. I’m trying to set up my mt6000 using a virgin hub. I’ve set my hub to modem mode and connected via Ethernet to the wan port but it’s saying the cable isn’t connected. I’ve tried other cables and rebooted the router but not luck. Should I user a lan port?
no always WAN port. LAN port is only for your internal network - so your clients or any other devices. I don't know Virgin, so I am not completely sure what you need to do now.
There are some known compatibility issues with the 2.5 Gbps port of the Flint2 and other devices. If you know how to SSH into your Flint, you can force it to be 1 Gbps - which might solve this issue.
If you don't know how to do so, let me know!
