Set up site not working; http://192.168.8.1
I just purchased the GL-MT3000 (FCC ID: 2AFIW-MT3000) but it will not let me set up. The setup web address http://192.168.8.1/ is not working, so I don’t know how to obtain my wifi password to use wifi with my unit.
The default WiFi password and QR code to connect is on the bottom of the MT3000.
same with me...not able to access admin portal since yesterday.... also my flint2 went offline just before that...now its shows "connected but no internet" ...mine is connected via cable to main ATT fiber modem & router...so luckily I still have my original network, but my vpn secured network is gone.
Not sure if i understand this correctly. You are not connected to the wifi before trying to access the router web interface? You will find the SSID + password on the bottom of your router.
You can only access the web interface when you are connected to your router.
Thank you!
Thank you! It's up and running now
