I am currently using a Huawei B525s 4G lte to connect to the internet this is giving internet to the GL-X750 via Ethernet cable to the wan port (192.168.8.X).
I have a GL.iNet Spitz (GL-X750) that I use to create a 5g wireless network (wireless network A) (for work devices).
I also use a home a second network a guest(limit what the guests can do and be able to stop the network when bandwitht is low) 2,4gh guest for other devices. (wireless network B)(for private devices)
I have also set up a wiregard interface WG.
GL-X750 has the capability to set up 4 wirteless networks I only need to use two A and B.
The issue is that A and B both sit behind the WG interface, I only need A to sit behind wg.
Ideally I want to get rid of the Huawei and just use the (GL-X750).
I am sure you guys might find this easy to solve, but please explain things is as much detail as possible.
No that’s not the requirement.
My requirement is for the guest network reffered to as (B) not to use the wireguard interface, but distribute the internet coming from the master huawei rooter.
Why Spitz has a SSID named HUAWEI-B525-3B3D, is that the same with your Huawei B525s 4G lte modem?
If you using Spitz’s wifi, how the traffic should be when using guest and private wifi?
