Hi there, I’m trying to set a Bluetooth dongle on a x750, I followed this doc [OpenWrt Wiki] USB Bluetooth support.
All seems good as the dongle is up
root@GL-X750:~# hciconfig
hci0: Type: Primary Bus: USB
BD Address: E8:48:B8:C8:20:00 ACL MTU: 1021:6 SCO MTU: 255:12
DOWN
RX bytes:1323 acl:0 sco:0 events:80 errors:0
TX bytes:1130 acl:0 sco:0 commands:79 errors:0
root@GL-X750:~# hciconfig hci0 up
UP RUNNING
RX bytes:1998 acl:0 sco:0 events:122 errors:0
TX bytes:1858 acl:0 sco:0 commands:121 errors:0
But when I try to config a Beacon nothing happens, the weird thing is a simple scan doesn’t show anything…
root@GL-X750:~hcitool -i hci0 scan
Scanning ...
root@GL-X750:
I’m pretty sure there are bluetooth devices around and that the dongle works as I checked using the same dongle in a PC
Furthermore, bluetoothctl does not seem to work as it can’t register or even the contoller
root@GL-X750:~# bluetoothctl
[bluetooth]# nnect to bluetoothd...
[bluetooth]# devices
No default controller available
[bluetooth]# power on
[bluetooth]#
Am I missing something here?
Thank you in advance
