Setting up Filesharing and DNLA on OPAL
Hello
I am unable to find the Files sharing option under Applications as shown in this post
I am also unable to find the packages mentioned in this post
Could you tell me what packages need to be installed for my router to share USB data on the network (PC and Mac Access) as well as DNLA server sharing for TV's
Thank you so much
If use the File Share in the Opal, please use the firmware v3.x, since the hardware performance of the Opal, SDK4 new codes (like for the VPN features) require to higher performance, so the Opal does not have the Fire Share in v4.x.
Thank you so much for your reply.
I am currently not using the VPN settings at all. I'd be happy to erase those and use file sharing.
Would you have instructions on how to do that? As file sharing is more important to me
Thank you so much for your time and help
