Has anyone successfully setup a Ftp server on the slate ax? I am currently tryng to set one up with vsftpd and no luck.
What is the problem then?
I tried to install vsftp and it just works.
Then need to edit /etc/vsftpd.conf to configure users etc.
I just enabled anonymous and test
anonymous_enable = YES
Then restart vsftpd
/etc/init.d/vsftpd restart
I can just access and upload files.
So it works OK. Just need to take some time to configure it.
So what i am trying to do is upload photos and video wireless from a sony camera to a connected ssd via the usb port. I cant use annonymous login and needs to have credentials. I have created a user and password.
The only info i need on the camera is ip address, login credentials, and a location to send the files. But i cannot connect to the ftp server.
