Setting up home VPN Server and Client Beginner guide?
I’m a complete noob when it comes to Networking. Saw a couple of youtube video and liked the benefit of a VPN server at home. I bought Slate AX and Beryl AX devices hoping that it would be an easy setup, but I failed miserably. I’m currently connected my Modem/Router to the Slate AX through Ethernet, then went on to create the Wireguard Server stuff, then tried to connect the Beryl AX through Wireguard Client, but it didn’t work. I have no clue if I have a public IP address or not. Don’t know how to do port forwarding from my ISP modem (Xfinity). Can someone help to guide me through this process?
Below are the errors that I see
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): Warning: fw3_ipt_rule_append(): Can’t find match ‘connmark’
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Zone ‘lan’
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Zone ‘wan’
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Zone ‘guest’
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Zone ‘wgclient’
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Set tcp_ecn to off
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Set tcp_syncookies to on
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Set tcp_window_scaling to on
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Running script ‘/etc/firewall.nat6’
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Running script ‘/etc/firewall.vpn_server_policy.sh’
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Running script ‘/var/etc/gls2s.include’
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): ! Skipping due to path error: No such file or directory
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): * Running script ‘/usr/bin/gl_block.sh’
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): Failed to parse json data: unexpected character
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): uci: Entry not found
Mon Mar 18 18:15:52 2024 daemon.notice netifd: wgclient (1205): cat: can’t open ‘/tmp/run/wg_resolved_ip’: No such file or directory
Mon Mar 18 18:15:52 2024 daemon.notice netifd: Interface ‘wgclient’ is now down
Mon Mar 18 18:15:52 2024 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Mon Mar 18 18:15:52 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Would it be possible to completely bypass Xfinity’s modem/router by turning the modem to bridge mode and then use my own router to do port forwarding?
