Looking to get a Wireguard server set up on a Flint 2 router.
I have an AT&T ISP Router/Modem AT&T HUMAX BGW320-500. From the setting menu. I'm looking to set up the port forwarding via the Custom Service entry. What are the following entries do I need to fill out?
Global Port Range ??
Base Host Port ?
Protocol - should I use TCP/UDP, UDP or TCP.
Have you considered putting the AT&T gateway in bridge mode and using the Flint 2 for both routing/wifi and WireGuard? Might make things easier and from my observations putting the gateway in bridge mode is a pretty common thing people do with the BGW320 for a variety of reasons.
