I want to access a computer the router’s network from outside without VPN. How can I do that?
Here are my settings right now: Imgur: The magic of the Internet
When I ssh, it’s not working
My external IP is the one I get from https://whatismyipaddress.com/ and not the one in the home page of router setting, right?
No it should be enough with just port forward.
How are you testing if you are able to access the PC?
Are you trying to go to the external ip you got from the site, from your internal network?
If yes, it won’t work, you should try it from a mobile phone or another network that is not yours.
Also, since its a x750, are you using the modem on it to get internet access? Your operator might have Double NAT, then your IP is shared and you won’t be able to run a server via your operator unless you pay for a fixed public IP.
