Setting up Unbound recursive dns server
Adguard is up and running.
Where can i get instructions on how to setup unbound recursive dns and have my adguard use it.
I have the Flint 3
same question.
Install unbound, enable it. In adguard point as dns only to localhost:5353 - 127.0.0.1:5353 (if port in unbound is 5353). Disable cache in adguard and set it as 0. Done.
That worked! Thanks @MucFlyer .
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
For DNSSEC, I’m not getting ‘ad’ Authentication Data, so my query is not validated.
Is there a quick solution for this?
