I was wondering if anyone had success setting up v2ray (Project V · Project V Official) on OpenWRT? I found some links on setting it up but they’re all in Chinese and most of them refer to GitHub - coolsnowwolf/lede: Lean's LEDE source which I don’t know is compatible with the router nor how to install.
I knew it, but it is designed for PC, not router.
On router, I think WireGuard should be best.
Any luck getting v2ray on these OpenWRT devices?
I managed to get the server installed on my Raspberry Pi, but need to add v2ray to the gl-ss client on the GL router.
This one is quite powerful.
Just wondering any possibility to get SSR Plus+ run on 750s? Thank you
yes, it works with v2ray
