Hi all - hope you can help. I have purchased the MT2500 and would like to setup as a drop in router so in essence, keep my ISP Modem/Router.
I can access the admin console and change to drop in router however when I do this and connect via the image, I cannot connect to the device.
I have set a static IP address on the MT2500 within range of my DHCP scope from main ISP router and also reserved this address on my main ISP Router. When I connect the wan port of the MT2500 to the lan port of my router, I cannot access it. Please could you assist.
Spent hours trying to make it work but cannot figure it out.
I reset the router and enabled dropin gateway and it now works for a short period of time (5-10mins). After this I lose access to the router and can no longer access the GL router (using default IP of 192.168.8.1). If I power down the router and power back up, I am able to access again but again after a short period of time, I lose access. Please could you assist?
