i purchase a GL-MV1000 / Brume from you which i want to put between my existing Asus Router and the Providers Modem.
My Provider requires besides the PPPoE Login and Password also a Special MAC to be set up which is 10:b3:6f:31:xx:xx and the Enable VPN + DHCP Connection to NO. Under LAN - IPTV the Internet Setting needs to be VID 10.
Those settings are right now in my Asus and if im correct if i want to put the Brume between those i have to get into the Brume.
