Hello!
Is it possible to create several vpn connections on one gl-inet router at the same time?
Regards
Mikee
Hello!
Regards
Mikee
It is possible, but it is complicated. You have to deal with VPN policy routing. Why do you want to use it?
First of all in a proof of concept. Secondly I have got trouble with long lasting vpn connections, that do perform badly. If it would be possibly to setup a routine, checking the internet speed / performance, a vpn routing policy could set up the preferred path to the internet, like failover.
ok, sorry I cannot help more, to see if others can help. If you success to try it by yourself, I would appreciate if you could share with us.
Yes, of course, I will share the information… Thx and bye
