SFT-1200 Opal tinc problem
I installed Tinc on Opal. Everything seems to be OK, but in tmp there is no tinc directory with complete configuration, in log I cannot see anything. Deamon seems to start. Any idea?
Can check what configuration running in the deamon
Init.d tinc script started O.K. Script should create directory tinc in tmp, which contains complete configuration and lists hosts file for tinc. But it dosnt happen for some reason. There is no error message, nothing. I will examine script further - i put several echo s in script to see what is happening.
Solved: just stupid error in config tinc, disabled tinc net
