SFT 1200 (OPAL)
Bought it on amazon a while back. Firmware 4.3.25. I have several access points at home. And they all work fine without gl inet opal. As soon as you connect any network via opal the network keeps disconnecting. I have to go into the settings. Delete the network. Connect again by entering the password. Otherwise it does not connect. Very annoying for three days of use. Is there any solution or is it better to make a return?
I bought a slate ax. No such problem. Testing for two days. Opal sent back to the seller
Is the SSID of several APs at home all the same?
In an environment with multiple APs, Opal may switch to each other of APs at the signal edge, casing the repeater instability.
Slate AX will be much better on this environment. Thanks for your feedback.
