Hi everybody my router GL.iNET AC1200 Wireless Travel Router don't work with the UTP-RJ-45 cable to the computer, works with the wireless but nothing with the ethernet cable, any advise for troubleshooting?
LOL! Now that shouldn't be the case. SSH into your Opal & post the output of logread -e netifd after a fresh boot with all the cables plugged in where appropriate.
Use ``` before & after the lines
like this
Please try changing the network port and network cable to see if you can successfully obtain the IP address assigned by DHCP.
You can also try upgrading the router's firmware to the latest version.
If that doesn't work, you can try pressing and holding the reset button on the side of the router for 10 seconds to restore it to factory settings.
