SlowMoe
February 27, 2025, 5:43am
How do you setup the router for use with a SFTP server? Do you have to use luci? Im lookinig for a good tutorial
bruce
February 27, 2025, 6:59am
2
Yes, SFTP uses the Luci, please check this tutorial:
LuCI support for VSFTP server
VSFTPd is a FTP/S daemon. opkg update && opkg install openssh-sftp-server requires no additional configuration for SFTP but it's much slower than a properly configured FTP/S.
In computing, the SSH File Transfer Protocol, also known as Secure File Transfer Protocol (SFTP), is a network protocol that provides file access, file transfer, and file management over any reliable data stream. It was designed by the Internet Engineering Task Force (IETF) as an extension of the Secure Shell protocol (SSH) version 2.0 to provide secure file transfer capabilities, and is seen as a replacement of File Transfer Protocol (FTP) due to superior security. The IETF Internet Draft sta Th...
FTPS (also known as FTP-SSL and FTP Secure) is an extension to the commonly used File Transfer Protocol (FTP) that adds support for the Transport Layer Security (TLS) and, formerly, the Secure Sockets Layer (SSL, which is now prohibited by RFC7568) cryptographic protocols.
FTPS should not be confused with the SSH File Transfer Protocol (SFTP), a secure file transfer subsystem for the Secure Shell (SSH) protocol with which it is not compatible. It is also different from FTP over SSH, which is the...
system
Closed
January 22, 2026, 9:37pm
7
