Trying to put the ARM-150 behind my wired Linksys. Using DHCP on WAN port doesn’t seem to work; shows not connected. When I put a static IP on the port it shows connected but I am unable to connect to Internet via the LAN port. Topology is as follows:
Cable Modem 68.0.0.0 <------> 68.0.0.0 Linksys (acting as DHCP) 192.168.1.1 <—> Wireless Bridge to basement <–> Wired Switch <–> 192.168.1.0 ARM-150 WAN Port 192.168.1.2 (static)
If I understand correctly, both the Linksys router and the ARM-150 are on a 192.168.1.x subnet. They need to be on different subnets. Set the ARM-150 on 192.168.2.x or higher.
