I’ve been using the GL.iNet GL-B1300 router with Shadowsocks and ChinaDNS. However, I noticed that the firmware was upgraded to 3.022 and my existing services/settings related to shadowsocks are all gone!
I was trying to install it again. When I click on the “Update” button on the “Plug-ins” page, it’s loading forever and doesn’t seem to work.
I can install gl-ss plug-ins on “Plug-ins” page on GL-B1300 v3.022.
I think that was the network problem you can not update the “Plug-ins”, please try again later.
I tried that. The new version can’t add new OpenVPN config (after uploading the file and entering the username, passwd and hit add, nothing happens). And Wireguard doesn’t work (it’s showing connected, but there’s connection to the internet. Can’t visit any site.).
I was able to add a couple of openvpn profiles after making exceptions on my antivirus software. However, it looks like openvpn doesn’t work in China (which was the why i was trying to set up shadowsocks).
Is it possible to fix your plug-ins update script URL or network issues so that users in China can easily update plug-ins? So far it’s been really painful.
I have to say that this is not easy to solve. We do not support these functions in China and we will not use server for this in China as well. Sorry for this.
I finally got plug-ins updated and was able to install gl-ss. However, I’d like to set up Shadowsocks to bypass websites in China. I installed the chinadns plug-in, but I don’t know how to set up SS to bypass China IPs using the main interface. Any advice? Thanks!
