Is it possible to start/stop the wireguard server and the openvpn client via shell script or shell command?
You can use following commands
For Openvpn
/etc/init.d/startvpn start
For Wireguard
/etc/init.d/wireguard start
Great - thanks!
Is there a possibility to specify the OpenVPN-Client profile when starting the OpenVPN client via shell command?
You can specify the OpenVPN-Client profile in /etc/config/glconfig
I see! Many thanks! Cheers
Just tried - is not working. Command is accepted but either VPN Client can be started or stopped nor the Wireguard Server can be started or stopped - just nothing happens…
You need to give logs. Post your screenshot of your shell commands, including ‘ps’ to list the processes.
It’s interesting information.
