Side switch problem
Hello there! I found issue with the side switch not working for reason below:
The switch stops working for any gl-scripts if the http port is different from 80 in the security settings (192.168.2.1/#/security).
I am attaching screenshots:
Works fine:
work_fine
Not working:
doesnt_work
Please, remove side switch dependency on port 80 in the web interface, so that any free port can be assigned and the switch will still work.
Hardware: GL-AXT1800
Firmware version: 4.5.16 and 4.6.2
Check and confirmed, will submit.
Thank you!
Reason is, btw, that the switch-scripts will use RPC to change settings. So they need access to the Web GUI. Since the script will only use http it will fail if you force https
