Hello, I have been tasked with conducting a SIM card audit for my company. One of the pieces of information that I need from each modem is the CCID which can be obtained running the QCCID command in the modems terminal window. This works for retrieving a single unit but I have several hundred devices to pull. It would be helpful if the CCID could be added as an additional column in the group list dashboard then I could just export the entire data set together.
Alternatively does anyone know how I could write a simple script that would automate the process of logging into each modems terminal and running the QCCID command and then recording the results?
