I have received this unit GL-E750V2 2 days and everything seemed to be working until this evening.
Every 20 MIN it disconnected
No internet! and I have to reboot.
I continued on with the troubleshooting and 1st I replaced the sim card and the issue persisted.
I finally went ahead and restored the firmware u-boot and the unit has now been connected without a drop for the last 7 Hours.
I think the unit is fragile any changes that is made on the network portion causes the modem to disconnect and I think I did something wrong.
For now it is working.
And it disconnected again, but for a few minutes:
Can someone tell me why it is still disconnecting
[16785.052580] CPU: 0 PID: 8 Comm: ksoftirqd/0 Not tainted 5.10.176 #0
[16785.052588] Stack : 80870000 8076ebd8 00000000 00000000 80c45cc4 809b0000 80800000 8073cd60
[16785.052625] 80c2a708 807f9e47 809b32d0 00000008 00000000 00000001 80c45c78 55ea9859
[16785.052661] 00000000 00000000 8073cd60 80c45b18 ffffefff 00000000 00000000 ffffffea
[16785.052696] 0000019e 80c45b24 0000019e 807ffb48 00000000 00000009 80c45d58 805367e0
[16785.052732] 00000009 00000000 00192779 80869cf4 00000018 0000003c 00000000 809b0000
[16785.052767] ...
[16785.052777] Call Trace:
[16785.052807] [<80066ea4>] show_stack+0x30/0x100
[16785.052828] [<80085b54>] __warn+0xb0/0x11c
[16785.052840] [<80085c4c>] warn_slowpath_fmt+0x8c/0xac
[16785.052857] [<805367e0>] dev_watchdog+0x26c/0x274
[16785.052888] [<800d09a4>] call_timer_fn.constprop.0+0x1c/0x8c
[16785.052901] [<800d0ce0>] run_timer_softirq+0x2cc/0x364
[16785.052934] [<8069f770>] __do_softirq+0x118/0x2ec
[16785.052950] [<80088ed8>] run_ksoftirqd+0x38/0x4c
[16785.052973] [<800a8c3c>] smpboot_thread_fn+0x148/0x1a0
[16785.052994] [<800a37dc>] kthread+0x13c/0x144
[16785.053008] [<80062258>] ret_from_kernel_thread+0x14/0x1c
[16785.053019]
[16785.053025] ---[ end trace e3b62f65b05e0c2f ]---
[17018.157304] usb 1-1.1: USB disconnect, device number 3
[17018.168714] usb 1-1.2: USB disconnect, device number 4
[17018.169041] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[17018.169207] option 1-1.2:1.0: device disconnected
[17018.169739] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[17018.169882] option 1-1.2:1.1: device disconnected
[17018.193671] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[17018.193814] option 1-1.2:1.2: device disconnected
[17018.194542] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[17018.194696] option 1-1.2:1.3: device disconnected
[17018.225668] qmi_wwan 1-1.2:1.4 wwan0: unregister 'qmi_wwan' usb-1b000000.usb-1.2, WWAN/QMI device
[17018.562801] usb 1-1: reset high-speed USB device number 2 using ehci-platform
[17019.111672] usb 1-1.1: new high-speed USB device number 5 using ehci-platform
[17019.274202] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[17019.318866] scsi host0: usb-storage 1-1.1:1.0
[17019.422025] usb 1-1.2: new high-speed USB device number 6 using ehci-platform
[17019.573197] usb 1-1.2: config 1 has an invalid interface number: 12 but max is 5
[17019.573219] usb 1-1.2: config 1 has no interface number 5
[17019.586603] option 1-1.2:1.0: GSM modem (1-port) converter detected
[17019.586895] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
[17019.587548] option 1-1.2:1.1: GSM modem (1-port) converter detected
[17019.587814] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
[17019.588449] option 1-1.2:1.2: GSM modem (1-port) converter detected
[17019.588715] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
[17019.589347] option 1-1.2:1.3: GSM modem (1-port) converter detected
[17019.589630] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
[17019.622216] qmi_wwan 1-1.2:1.4: cdc-wdm0: USB WDM device
[17019.623386] qmi_wwan 1-1.2:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 qmi wwan detected
[17019.624466] qmi_wwan 1-1.2:1.4 wwan0: register 'qmi_wwan' at usb-1b000000.usb-1.2, WWAN/QMI device, aa:af:43:cd:9e:4f
[17020.333820] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 0233 PQ: 0 ANSI: 0
[17021.454851] sd 0:0:0:0: [sda] Attached SCSI removable disk
And now it is now again disconnecting... There is nothing more I can do as there are several posts that have the same symptoms and have gone unanswered.
Returning the unit!
Sorry.
Please contact our support team support@gl-inet.com, cite this thread and provide the completely syslog to check.
Sorry the unit was returned.
