Hi, I have a problem with GL-MIFI-695. On modem section shows “SIM card not registered”. I double-checked the SIM and is correct.
Any idea?
Here is the log.
Mon Jul 27 17:44:52 2020 daemon.err gl_monitor[3200]: killall: gcom: no process killed
Mon Jul 27 17:44:52 2020 daemon.info pppd[10038]: Terminating on signal 15
Mon Jul 27 17:44:52 2020 daemon.notice pppd[10038]: Connection terminated.
Mon Jul 27 17:44:53 2020 daemon.err gl_monitor[3200]: killall: uqmi: no process killed
Mon Jul 27 17:44:53 2020 daemon.info pppd[10038]: Exit.
Mon Jul 27 17:44:53 2020 daemon.notice netifd: Interface 'modem_1_1_2' is now down
Mon Jul 27 17:44:53 2020 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Mon Jul 27 17:44:53 2020 user.notice root: modem_1_1_2 interface miss
Mon Jul 27 17:44:55 2020 user.debug : devices=null
Mon Jul 27 17:44:57 2020 daemon.notice netifd: modem_1_1_2 (11550): SIM ready
Mon Jul 27 17:44:57 2020 daemon.notice netifd: modem_1_1_2 (11550): PIN set successfully
Mon Jul 27 17:44:57 2020 daemon.notice netifd: modem_1_1_2 (11550): cat: can't open '/tmp/modem.1-1.2/signal': No such file or directory
Mon Jul 27 17:44:58 2020 daemon.notice pppd[11655]: pppd 2.4.7 started by root, uid 0
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: abort on (BUSY)
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: abort on (NO CARRIER)
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: abort on (ERROR)
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: report (CONNECT)
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: timeout set to 10 seconds
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: send (AT+CGDCONT=1,"IP","airtelwap.es"^M)
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: timeout set to 30 seconds
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: expect (OK)
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: ^M
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: OK
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: -- got it
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: send (ATD*99***1#^M)
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: expect (CONNECT)
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: CONNECT
Mon Jul 27 17:44:59 2020 local2.info chat[11719]: send ( ^M)
Mon Jul 27 17:44:59 2020 daemon.info pppd[11655]: Serial connection established.
Mon Jul 27 17:44:59 2020 kern.info kernel: [ 398.914936] 3g-modem_1_1_2: renamed from ppp0
Mon Jul 27 17:44:59 2020 daemon.info pppd[11655]: Using interface 3g-modem_1_1_2
Mon Jul 27 17:44:59 2020 daemon.notice pppd[11655]: Connect: 3g-modem_1_1_2 <--> /dev/ttyUSB3
Mon Jul 27 17:45:00 2020 user.debug : devices=null
Mon Jul 27 17:45:05 2020 user.debug : devices=null
Mon Jul 27 17:51:38 2020 daemon.info pppd[11655]: System time change detected.
Mon Jul 27 17:51:41 2020 user.debug : devices=null
Mon Jul 27 17:51:46 2020 user.debug : devices=null
Mon Jul 27 17:51:51 2020 user.debug : devices=null
Mon Jul 27 17:51:56 2020 user.debug : devices=null
Mon Jul 27 17:52:01 2020 user.debug : devices=null
Mon Jul 27 17:52:02 2020 daemon.warn pppd[11655]: IPV6CP: timeout sending Config-Requests
Mon Jul 27 17:52:06 2020 user.debug : devices=null
Mon Jul 27 17:52:11 2020 user.debug : devices=null
Mon Jul 27 17:52:16 2020 user.debug : devices=null
Mon Jul 27 17:52:21 2020 user.debug : devices=null
Mon Jul 27 17:52:26 2020 user.debug : devices=null
Mon Jul 27 17:52:28 2020 daemon.err gl_monitor[3200]: killall: gcom: no process killed
Mon Jul 27 17:52:28 2020 daemon.info pppd[11655]: Terminating on signal 15
Mon Jul 27 17:52:28 2020 daemon.notice pppd[11655]: Connection terminated.
Mon Jul 27 17:52:29 2020 daemon.err gl_monitor[3200]: killall: uqmi: no process killed
Mon Jul 27 17:52:29 2020 daemon.info pppd[11655]: Exit.
Mon Jul 27 17:52:29 2020 daemon.notice netifd: Interface 'modem_1_1_2' is now down
Mon Jul 27 17:52:29 2020 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Mon Jul 27 17:52:29 2020 user.notice root: modem_1_1_2 interface miss
Mon Jul 27 17:52:31 2020 user.debug : devices=null
Mon Jul 27 17:52:33 2020 daemon.notice netifd: modem_1_1_2 (13168): SIM ready
Mon Jul 27 17:52:33 2020 daemon.notice netifd: modem_1_1_2 (13168): PIN set successfully
Mon Jul 27 17:52:33 2020 daemon.notice netifd: modem_1_1_2 (13168): cat: can't open '/tmp/modem.1-1.2/signal': No such file or directory
Mon Jul 27 17:52:33 2020 daemon.notice pppd[13337]: pppd 2.4.7 started by root, uid 0
Mon Jul 27 17:52:34 2020 local2.info chat[13338]: abort on (BUSY)
Mon Jul 27 17:52:34 2020 local2.info chat[13338]: abort on (NO CARRIER)
Mon Jul 27 17:52:34 2020 local2.info chat[13338]: abort on (ERROR)
Mon Jul 27 17:52:34 2020 local2.info chat[13338]: report (CONNECT)
Mon Jul 27 17:52:34 2020 local2.info chat[13338]: timeout set to 10 seconds
Mon Jul 27 17:52:34 2020 local2.info chat[13338]: send (AT+CGDCONT=1,"IP","airtelwap.es"^M)
Mon Jul 27 17:52:35 2020 local2.info chat[13338]: timeout set to 30 seconds
Mon Jul 27 17:52:35 2020 local2.info chat[13338]: expect (OK)
Mon Jul 27 17:52:35 2020 local2.info chat[13338]: ^M
Mon Jul 27 17:52:35 2020 local2.info chat[13338]: OK
Mon Jul 27 17:52:35 2020 local2.info chat[13338]: -- got it
Mon Jul 27 17:52:35 2020 local2.info chat[13338]: send (ATD*99***1#^M)
Mon Jul 27 17:52:35 2020 local2.info chat[13338]: expect (CONNECT)
Mon Jul 27 17:52:35 2020 local2.info chat[13338]: CONNECT
Mon Jul 27 17:52:35 2020 local2.info chat[13338]: send ( ^M)
Mon Jul 27 17:52:35 2020 daemon.info pppd[13337]: Serial connection established.
Mon Jul 27 17:52:35 2020 kern.info kernel: [ 463.676691] 3g-modem_1_1_2: renamed from ppp0
Mon Jul 27 17:52:35 2020 daemon.info pppd[13337]: Using interface 3g-modem_1_1_2
Mon Jul 27 17:52:35 2020 daemon.notice pppd[13337]: Connect: 3g-modem_1_1_2 <--> /dev/ttyUSB3
