I've been having a hard time setting up my GL-X750. I can't get any internet access & my sim card is showing as not registered. The sim card came from my phone so I know it is registered with a phone number. The sim card is with Metro by T-Mobile.
Please update your router to the newest available firmware, if not already done: GL.iNet download center
After that: Do you know if the SIM might be locked to the phone?
I've updated to the newest firmware. I called metro by t mobile & they said the sim card is unlocked. It's not locked to any phone.
This is how it looks with the new update.
Can you try clone your phone's IMEI to the router and try?
Don't use the phone for T-Mobile at the same time.
That worked. Appreciate the help!
