The SIM card is not detected.
Message on the OLED is "Insert SIM Card and Reboot".
in the Admin Panel, Cellular is indicated with the orange status light, and mention No SIM and SIM not detected.
already tried :
reinsert the SIM card and Reboot
Reboot modem
several SIM cards tested (BOUYGUES, SFR, ORANGE)
Test of the SIM card with another LTE 4G Modem (tp-link M7650) -> works
I guess the the router is not working and shall be returned to the seller.
It look crooked on the photo but it is not, it can move slightly to be straight.
But it can definitely not be inserted fully. It seems the SIM slot is not OK.
I will sent the router back.
Thanks
I've exactly the same issue.
SIM card is from elliot, works in a GL-xe3000c4.
But the E750v2c6 EM060KGL keeps saying insert sim card.
What was the fix?
pls make sure the sim card is inserted in the correct direction
reboot the router to see if it can detected
add a piece of paper to the non-contact surface of sim card and reboot the router to try.
If issue persists, pls share a screenshot of the INTERNET page, and run the following AT command under Modem Management page and post the command output with us to check: AT+CFUN?;+QCCID;+CPIN;+QUIMSLOT?
Thank you for the quick response.
Sim was correct installed and tried reboot several times.
Added a piece of paper, but is was already quite tight, did not help.
There does not seem to be a modem management page when there is no sim card detected?
