I have a GL-X3000. SIM card requires a 16 digit PIN, but Admin Panel/Network page only supports 8 digit PIN. How do I resolve this problem?
Thanks!
AT+CPIN="xxxxxxxxxxxx"
Is this command useful?
I can try. How do i get to a prompt where i can issue AT commands? Does not aeem to be aan option from the Admin Center.
If this AT instruction doesn't work
Then you can only try to set the pin code to 4 digits from your phone
Unfortunately phone only has eSIM. But will try using the AT command when I return later today.
