Simple way to enable https without Adguard Home?
I have a Beryl AX and a Flint 2. Is there a simple way to enable https without enabling Adguard Home? Both devices are using 4.7.0.
Thanks... Duncan
What do you mean by 'enabling https'?
Turn it on.
Thanks...
AdGuard Home isn't required for any https thingy.
So this isn't a valid procedure then: How to use HTTPS to access GL-iNet Routers and Adguard Home? - GL.iNet Router Docs 4 ?
Only needed if you want to use DNS-over-HTTPS.
By default the routers interface can be reached via HTTPS.
When I connect from the Internet, Chrome complains that the connection is not secure.
