It will work? If yes where I can manage the eSIM profiles? Now is connected to a Beryl AX.
Thanks for any information.
L.
L.
The SIMPoYO uFi can work with the SIMPoYO Physical eSIM Card, but it does not support eSIM profile management features.
You may need to use an Android phone to manage these profiles. For details, please refer to: How to use the eSIM Physical Card with Android devices
Thanks for the info. However, below the chat with customer support :
Me: One more thing....Is eSIM card compatible with my SIMPoYo uFi (SP-N150C4) Plug & Play 4G USB Dongle? I have it connected to a Beryl router.
Nicholas Yes the Physical eSIM card is compatible with the SIMPoYo uFi
Me: Once the eSIM card is inserted in my SIMPoYo uFi (that is connected to my Beryl), where is the menu to add SIM profiles? How can I manage it?
Nicholas To manage your eSIM profiles on your GL.iNet router, follow these steps:
1. Access the Admin Panel of your router (Beryl).
2. Navigate to the "APPLICATIONS" section.
3. Look for "eSIM Management" or "eSIM Manage" in the menu.
Once you're in the eSIM Management section, you can add, enable, or delete eSIM profiles as needed. If you have any specific questions or need further assistance, feel free to ask! Enjoy managing your eSIM profiles!
Me: Now, there is no such thing as eSIM Management in APPLICATIONS. It will be available when the eSIM will be inserted in SIMPoYo uFi modem?
Nicholas : Yes, that's correct! The eSIM Management option will become available in the Admin Panel once the eSIM card is inserted into the SIMPoYo uFi modem and the device is powered on. After inserting the eSIM, you should be able to access the eSIM Management section under the Applications menu to manage your eSIM profiles. If you have any further questions or need assistance, feel free to ask!
I think there may have been a misunderstanding.
The eSIM Management option only appears when the physical eSIM is inserted directly into one of our cellular routers that supports eSIM management. You can find the specific list of supported devices here: How to use eSIM Physical Card with GL.iNet Routers
Using it through the SIMPoYO uFi does not support eSIM management because the router cannot interact directly with the cellular module in that configuration.
I also thought that but… worth a try.
However, alternative scenario:
Using the eSIM first in my android Oneplus Nord 3 phone to download, manage, etc the profiles and then to put it in the Dongle? Is it doable? I mean, I will be able to use it like a normal SIM card, seeing in the Dongle setting interface the info for the eSIM profile that was last enabled In my phone.
What do you think?
BR.
Yes, your understanding is correct.
You can download, activate and manage the eSIM profile on an Android phone first, then insert the card into the uFi for use. The profile that was last activated on the phone will be the one that remains active and functional.
Yeap. That's how I will do it. Thanks a lot for the info.
Best regards. K.
Is there any plan on adding simpoyo esim profile management on the Simpoyo ufi dongle?
It would be better instead of moving the sim to the phone, changing the profile and then re-insert it in the dongle.
Thank you for your suggestion. We will forward this as a feature request to the product team for evaluation.
