Hi all.
I just received SIMPoYo uFi (SP-N150C4) stick with sim card. I would like to understand two things. Is this included card esim (allowing me to store profiles from providers) or just regular sim with roaming possibilities I have to top up using simpoyo web? (btw going to https://simpoyo.com/lander does nothing, just me or it doesn’t work?).
Can I simply remove this card, and put local provider sim into stick and use it?
Thanks, it seems bit confusing for me.
Hi!
Regarding your questions:
- The included SIM card is a standard SIM card which requires activation via SIMPoYo Website before it can be used. You can follow this tutorial to activate it: How to use SIMPoYo uFi - GL.iNet Router Docs 4.
- Yes, you can replace it with your own SIM card.
@will.qiu thank you for info, can I also use esim card (if yes what is recommended, compatible?) with stick ? Idea behind is to use esim profile, let’s say from German providers when I’m in Germany, or Polish provider being in Poland etc.
You can use a physical eSIM with the SIMPoYo UFi.
We recommend using one provided by our verified GL.iNet partners, as these have been tested to ensure compatibility:
EIOT CLUB: eSIM - GL.iNet physical eSIM | Free 1GB for US/EU and 100MB global Dat — GL.iNet US
SIMPoYo: SIMPoYo eSIM eSIM Physical Card and SIMPoYo SIM Card. - GL.iNet
Please note that the SIMPoYo UFi does not support eSIM profile management. If you need to switch eSIM profiles, this must be done on another device
Brilliant, I’ve tried to see plans and options, but seems web page is not working :
Thank you for your feedback.
This link appears to be broken, and we will ask SIMPoYo team to have a check.
For now, please use this link:
Update as of 12/12/2025:
The Plans - Simcard Glinet page should now return to work.
