Simultaneous VPN Client and Server Wireguard not working
I’m running GL-AX1800 with VPN Client Proton Wireguard active with all network traffic routed through Proton. I’m also running Adguard home through the VPN to prevent DNS leaks. I wanted to create a Wireguard Server so I can connect to my LAN when out of the home to make network adjustments if necessary.
I was able to create the server and scan the QR code with my Wireguard app. The app says it’s connected but I’m not receiving any internet traffic to the phone while on the cell network through the VPN server nor am I able to connect to any of the devices on the local network. I went as far as ensuring my server ports for proton werent conflicting with my personal server port.
What am I not doing right here?
Pictures of settings added for reference
Did you turn on the cascade switch?
Did you forward a UDP port on your main router (if the AX1800 is not the main router)?
I dont see a global option under VPN server section, only under the client section? What does the cascading do?
Ax1800 is the main router due to having wireguard VPN and my old one only having openvpn also 1800 has the adguard home features for ads
When the app says connected (does not mean much with WG BTW), can you browse the internet? Is it that you have a problem accessing internal servers (because on the screenshot you attached it shows some traffic)? If so, did you enable “access local network”?
Didnt realize it meant little with wireguard, thanks for that tidbit. I can do anything on the phone when it says im connected to my home networkl. internet and local clients cant be reached.
Are you sure you’re not behind a CGNAT?
If not. Examine the the generated WG configuration file and make sure it points to your DDNS or static public IP address (if you have one).
I turned on use DDNS under the wireguard profile and still no dice. The internet IP under the internet page does not match what my public IP is, likely because the proton VPN is on at the same time
It depends on how the AX1800 function in such a situation (I’ve never tried this as my main router is not a GL.iNet).
You can disable Proton VPN briefly and do the same comparison for the public and router ip addresses. While it’s disabled, try your phone again and see if you connect successfully.
When you check your router’s WAN ip address is it between 100.64.0.0 – 100.127.255.255?
With proton off im showing as a “client connected” under the server side but still cant do anything
If it shows that you’re connected now then you should at least be able to browse the internet through your home’s router and if the “allow LAN access” is enabled, you should be able to reach internal hosts.
Did you regenerate a new WG profile after disabling OpenVPN? If not, try it.
I’m not sure what to try next. Maybe making sure you’re on the latest firmware and rebooting the router.
Under Flint VPN settings it says the following,
Note that you can’t running VPN Client and Server at the same time, and also can’t running OpenVPN Client and WireGuard Client at the same time.
but I disabled the block non vpn traffic and it appears to connect although im not sure how to connect to LAN ip numbers
Here’s what the log says when I start it:
Mon Apr 10 08:50:21 2023 daemon.notice netifd: Interface ‘wgserver’ is now down
Mon Apr 10 08:53:14 2023 daemon.notice netifd: Interface ‘wgserver’ is setting up now
Mon Apr 10 08:53:14 2023 daemon.notice netifd: Interface ‘wgserver’ is now up
Mon Apr 10 08:53:14 2023 daemon.notice netifd: Network device ‘wgserver’ link is up
Mon Apr 10 08:53:14 2023 kern.info kernel: [21175.486046] IPv6: ADDRCONF(NETDEV_UP): wgserver: link is not ready
Mon Apr 10 08:53:14 2023 user.notice firewall: Reloading firewall due to ifup of wgserver (wgserver)
Mon Apr 10 08:57:15 2023 daemon.notice netifd: Network device ‘wgserver’ link is down
Mon Apr 10 08:57:16 2023 daemon.notice netifd: Interface ‘wgserver’ is now down
Mon Apr 10 08:57:27 2023 daemon.notice netifd: Interface ‘wgserver’ is setting up now
Mon Apr 10 08:57:27 2023 daemon.notice netifd: Interface ‘wgserver’ is now up
Mon Apr 10 08:57:27 2023 daemon.notice netifd: Network device ‘wgserver’ link is up
Mon Apr 10 08:57:27 2023 kern.info kernel: [21429.005656] IPv6: ADDRCONF(NETDEV_UP): wgserver: link is not ready
Mon Apr 10 08:57:28 2023 user.notice firewall: Reloading firewall due to ifup of wgserver (wgserver)
Mon Apr 10 08:59:24 2023 daemon.notice netifd: Network device ‘wgserver’ link is down
Mon Apr 10 08:59:25 2023 daemon.notice netifd: Interface ‘wgserver’ is now down
Mon Apr 10 09:02:21 2023 daemon.notice netifd: Interface ‘wgserver’ is setting up now
Mon Apr 10 09:02:21 2023 daemon.notice netifd: Interface ‘wgserver’ is now up
Mon Apr 10 09:02:21 2023 daemon.notice netifd: Network device ‘wgserver’ link is up
Mon Apr 10 09:02:21 2023 kern.info kernel: [21723.222684] IPv6: ADDRCONF(NETDEV_UP): wgserver: link is not ready
Mon Apr 10 09:02:22 2023 user.notice firewall: Reloading firewall due to ifup of wgserver (wgserver)
It’s a fairly straightforward setup, I’ve been able to test the same functionality (WG server) with my Beryl AX and Mango when I received them about five weeks ago, albeit not as main routers (had to forward ports to them). So your case should be easier since it’s the main router.
Sorry I have no more suggestions. You should contact support and refer them to this thread, hopefully you’ll get it resolved soon.
Versions later than 4.1.3 have this feature, try upgrading to the latest firmware.
I updated from 4.1.0 to 4.2.1 and it seems like everything is fixed now and working with this issue, thank you for that input!!! it never said update avail until I manually uploaded it. Im still tinkering around on random wifi 5ghz band freezes and random IoT devices continually dropping connection and reconnect.
IOT devices usually use 2.4g, try to set the mode of 2.4 to b/g/n mode in Wireless Settings
I made a short video of whats happening and uploaded it to Imgur. I made the adjustment you mentioned and still have the same result. Occasionally I’ll see the IoT device that’s bouncing on and off network flashing in the house (signaling it’s not connected) for a few seconds before reconnecting.
When a problem occurs, can you export log in SYSTEM->LOG?
