use my GL-MT2500 as DNS (IPv 4 & v6) with single NIC
use AdGuard
keep DHCP on my Fritzbox
name resolution on the GL-MT2500 for internal Clients, so I see my clients in the logs
What I do not want:
change something on my current network
use DHCP of the GL-MT2500
What are the basic settings to do all the above?
use only WAN port
as far as I understood I need to setup the drop-in Gateway function on the GL-ML2500
change the DNS servers on the Fritzbox to query the GL-ML2500 and to send them via DHCP
activate IP v6
But what do I have to setup that I get the local clients resolved in the AdGuard logs?
I always get a warning I shall switch the DHCP from the Fritzbox to the Gl-MT2500 which I do not want to.
I opened the firewall port an Brume2.
On a Fritzbox it’s not directly possible to edit option 6 of DHCP but I found the setting so that the DNS server is spread to the clients. I can confirm that the clients get the Brume2 as DNS Server via DHCP.
But I do only see 127.0.0.1 on the Brume2 in AdGuard in the logs.
I did configure the private inverse server on AdGuard like this:
