Hi mates! I know this question has been raised already, but no definite answer / solution so far.
I've setup a standard Site-to-Site connection in GoodCloud using Brume2 (Main Node) and MT300N-V2 (Node-1) which works well. Nodes are located in different countries.
I'm connected to Node-1 via WiFi, but need to have Internet from the Main node.
I understood S2S connection can't provide this functionality by default, but maybe someone know the 'custom' way?
In one of the forum posts was a proposal to use 'iptable rules'..?!
Getting ahead of the suggestion to use WireGuard / OpenVPN in Server and Client modes, I can say that it doesn't work for me, as the internet provider randomly blocks these connections, when the S2S remains stable.
Will appreciate any ideas how to solver this!!
The GoodCloud Site to Site does not support the exit node (main node) configuration.
As you mentioned, the Site to Site is based on the WireGuard protocol.
May you can try to learn about the AstroWarp platform.
Thanks for your response!
Yes, I read about AstroWarp, it should be perfect for my purpose.
However, it's not available yet. Do you know when it can be tested / used?
Thanks for the tip regarding the test firmware, I've just read the release notes of the Beta one, AstroWarp is indeed must be available there. I probably buy another Brume2 to test the platform.
I tried different ports on WireGuard server (currently 51850), but it's still blocked by provider from time to time.
