There is a problem with the 0612 release. I left it logged to the gui, otherwise the device is idling.
very high load averages and unusually high memory consumtion.
root@GL-AR750S:~# uptime
08:07:57 up 16:11, load average: 4.85, 4.95, 4.98
root@GL-AR750S:~# free -h
total used free shared buffers cached
Mem: 124396 94044 30352 3280 12588 28596
-/+ buffers/cache: 52860 71536
Swap: 0 0 0
@lancer Please check it out!
lancer
June 17, 2019, 8:40am
4
Hi, manderss99
What function did you open? I found api process and gl_health process exception from the image.
We have updated ar750s_3.025 testing firmware and made a lot of optimizations, you can download it from https://fw.gl-inet.com/firmware/ar750s/testing/openwrt-ar750s-3.025-0617.tar
Looking forward to your feedback. Thanks.
Installed 3.025 and left it running overnight, it seems the problem have been fixed,
Thanks
spoke too soon.
The problem remains on 3.025.
I logged into the router using firefox and left it on the main internet screen overnight.
05:47:21 up 11:11, load average: 5.55, 5.13, 4.9
dzwghx
June 19, 2019, 4:31am
7
What function did you open? How can I reproduce this problem?
I just logged in and left it on the default page (‘internet’) overnight.
in the morning I had this high load averages.
no other clients was connected, the router was just idling.
using latest firefox on mac if that matters.
alzhao
June 19, 2019, 12:57pm
9
What about you close the browser after high load? Will the load and memory come back to normal?
The internet page actually calls too many api again and agin. So high Cpu load and memory usage is normal.
The page is not responding at all.
in previous versions (0329 and others) the load average was below 1 in the same scenario so something is very wrong.
This is after closing the web browser, the load does average not decrease:
alzhao
June 20, 2019, 11:09am
12
What you have python 3 running?
What did you install?
it is a self made script to fetch statistics from e3372 modem which I invoked.
It was not run at time of previous tests and is not using gl api.
lancer
June 26, 2019, 9:47am
14
Hi,manderss99
We have update to 3.025-0626, we tested for two days and found no problems.
you can download it from https://fw.gl-inet.com/firmware/ar750s/testing/openwrt-ar750s-3.025-0626.tar
after running 0626 for two days everything is fine.
will report back if this issue reoccurs, thanks
