Slate 1800 & Huawei USB 4G Modem (E3372)
modem works if it is connected directly to PC.
Attached to router led is blinking repeatly red and green.
Router interface did not show opportunity to choose tethering or cellular to connect.
Looks linke router did not recongnize the USB modem.
Any ideas?
Greetings from Berlin
Mnem0
GL iNet Slate 1800 and Huawei Modem already have different host IP adresses.
hi,
Are you using Huawei E3372 or 3372-s106 or 3372-h106? Could you try to re-plug the modem after system up? I have the same issue if I start the system after Huawei 3276s is pluged.
Hi, in admin panel of the modem I found these infos:
Device name E3372-325
Hardware version CL5E3372M
Software version 3.0.2.61(H057SP5C983)
Web UI version WEBUI 3.0.2.61(W13SP3C7201)
I already tried to replugin the modem several times.
Sometimes for some seconds a tethering device was regonized, but after some seconds it was gone and no connection was built.
KR
Hi!
I have excactly the same problem.
Is there already a solution?
hi,
E3372-325 is not supported/adapted on glinet router.
And now? Make it supported?
The Flint2 Support that Stick. I have it. the Slate 1800 Stick dont suport it. Why?
Does Flint2 support connecting to E3372 and the Internet is normal?
Slate AX should also support it. Please ensure that after you plug the E3372 into the router USB, please wait for a while that the USB stick system has completed booting, and then click "Connect" in GL GUI.
Or SSH to router, and execute ifup tethering
Yes on the flint2 the Internet works fine. The Same Stick on a slate 1800 dont work. It Shows „No Internet Connection“
  1. Please connect the USB stick to Slate AX, export the syslog.
  2. Please connect the USB stick to Flint 2, export the syslog.
  3. You can share the Slate AX with us through GoodCloud, and let us try to check it.
    Please PM with me the above syslogs, Slate AX MAC address, and Admin Panel password.
