Slate 7 BBR CCA is slow
Upload throughput over bbr is ~1–2 Mbps or collapses to 0, while cubic approaches the real upload limit of the link (in this case, ~40Mbps).
iperf3 -p XXXX -c XXXXXXXX -t 5 --connect-timeout 5000 -V
iperf 3.16
Linux GL-BE3600 5.4.213 #0 SMP PREEMPT Fri Sep 18 12:42:12 2026 aarch64
Control connection MSS 1448
Time: Thu, 22 Oct 2026 19:08:43 UTC
Connecting to host XXXXXXXX, port XXXX
      Cookie: 4nuujpjf6n6vsy3pdg37nvs7uidjkmp6yz5h
      TCP MSS: 1448 (default)
[  5] local 192.168.202.244 port 56628 connected to XXX.XXX.XXX.XXX port XXXX
Starting Test: protocol: TCP, 1 streams, 131072 byte blocks, omitting 0 seconds, 5 second test, tos 0
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec  6.38 MBytes  53.4 Mbits/sec    0    407 KBytes
[  5]   1.00-2.00   sec  5.12 MBytes  43.0 Mbits/sec   15    164 KBytes
[  5]   2.00-3.00   sec  5.25 MBytes  44.0 Mbits/sec    4   97.6 KBytes
[  5]   3.00-4.00   sec  5.25 MBytes  44.0 Mbits/sec    0    132 KBytes
[  5]   4.00-5.00   sec  4.38 MBytes  36.7 Mbits/sec    1    119 KBytes
Test Complete. Summary Results:
[  5]   0.00-5.00   sec  26.4 MBytes  44.2 Mbits/sec   20             sender
[  5]   0.00-5.02   sec  24.1 MBytes  40.3 Mbits/sec                  receiver
CPU Utilization: local/sender 0.4% (0.0%u/0.4%s), remote/receiver 4.7% (0.2%u/4.4%s)
iperf 3.16
Time: Thu, 22 Oct 2026 19:08:48 UTC
      Cookie: apxkkcbewiexqcvzny73orr5ejiuamez7n7b
[  5] local 192.168.202.244 port 56642 connected to XXX.XXX.XXX.XXX port XXXX
[  5]   0.00-1.00   sec  0.00 Bytes  0.00 bits/sec    0   0.00 Bytes
[  5]   1.00-2.00   sec  0.00 Bytes  0.00 bits/sec    0   0.00 Bytes
[  5]   2.00-3.00   sec  0.00 Bytes  0.00 bits/sec    0   0.00 Bytes
[  5]   3.00-4.00   sec  0.00 Bytes  0.00 bits/sec    0   0.00 Bytes
[  5]   4.00-5.00   sec  0.00 Bytes  0.00 bits/sec    0   0.00 Bytes
[  5]   0.00-5.00   sec  0.00 Bytes  0.00 bits/sec    0             sender
[  5]   0.00-5.26   sec  0.00 Bytes  0.00 bits/sec                  receiver
CPU Utilization: local/sender 0.1% (0.0%u/0.1%s), remote/receiver 0.0% (0.0%u/0.0%s)
Thanks for reporting this.
Could you try the attached updated BBR package and let us know whether it resolves the low upload speed?
kmod-tcp-bbr_5.4.213-1_aarch64_cortex-a53_neon-vfpv4_be3600.ipk (5.6 KB)
We have already checked it locally, and it should fix the issue. Once you confirm, we will then update it in the repository.
Thank you for the update. We can confirm that the provided kmod appears to resolve the issue.
