Slate 7 - Btrfs support is broken since 4.7.2
Hello! I just got Slate 7 and was hoping to use it as a backup server to receive Btrfs snapshots to external HDD. However it seems like there's some issue with Btrfs' implementation since FW version 4.7.2.
Everything worked with out of the box on 4.7.1 but broke after upgrade to 4.7.3. I also checked 4.7.2 and this version is broken too.
You can find full command list to reproduce the problem below, but basically the problem boils down to the kernel module not been able to load:
On 4.7.2 and 4.7.3:
root@GL-BE3600:~# opkg install btrfs-progs
root@GL-BE3600:~# lsmod | grep btrfs
root@GL-BE3600:~# insmod btrfs
failed to insert /lib/modules/5.4.213/btrfs.ko
root@GL-BE3600:~# dmesg | tail -4
[ 2166.066041] btrfs: Unknown symbol __page_file_index (err -2)
[ 2166.067053] btrfs: Unknown symbol add_swap_extent (err -2)
[ 2596.513307] btrfs: Unknown symbol __page_file_index (err -2)
[ 2596.514047] btrfs: Unknown symbol add_swap_extent (err -2)
On 4.7.1:
btrfs                 991232  0
libcrc32c              16384  5 btrfs,act_csum,openvswitch,nf_nat,nf_conntrack
raid6_pq              102400  1 btrfs
xor                    16384  1 btrfs
zstd_compress         176128  2 zstd,btrfs
zstd_decompress        49152  2 zstd,btrfs
[ 2241.804930] kmodloader: loading kernel modules from /etc/modules.d/*
[ 2241.880220] Key type encrypted registered
[ 2241.937444] Btrfs loaded, crc32c=crc32c-generic
[ 2241.945148] kmodloader: done loading kernel modules from /etc/modules.d/*
Full command list to reproduce the problem:
root@GL-BE3600:~# opkg update
root@GL-BE3600:~# opkg install btrfs-progs wipefs
root@GL-BE3600:~# dd if=/dev/zero of=test bs=1M count=200
root@GL-BE3600:~# losetup -f test
root@GL-BE3600:~# losetup -a
/dev/loop0: [0020]:1169 (/root/test)
root@GL-BE3600:~# mkfs.btrfs /dev/loop0
btrfs-progs v6.5.1
See https://btrfs.readthedocs.io for more information.
NOTE: several default settings have changed in version 5.15, please make sure
      this does not affect your deployments:
      - DUP for metadata (-m dup)
      - enabled no-holes (-O no-holes)
      - enabled free-space-tree (-R free-space-tree)
Label:              (null)
UUID:               3bc1ff61-0e52-4189-bfce-26b54720851f
Node size:          16384
Sector size:        4096
Filesystem size:    200.00MiB
Block group profiles:
  Data:             single            8.00MiB
  Metadata:         DUP              32.00MiB
  System:           DUP               8.00MiB
SSD detected:       yes
Zoned device:       no
Incompat features:  extref, skinny-metadata, no-holes, free-space-tree
Runtime features:   free-space-tree
Checksum:           crc32c
Number of devices:  1
Devices:
   ID        SIZE  PATH
    1   200.00MiB  /dev/loop0
WARNING: failed to open /dev/btrfs-control, skipping device registration: No such file or directory
root@GL-BE3600:~# mount -t btrfs /dev/loop0 /mnt
mount: mounting /dev/loop0 on /mnt failed: No such device
root@GL-BE3600:~# ls -l /dev/loop0
brw-------    1 root     root        7,   0 Jul  2 21:42 /dev/loop0
root@GL-BE3600:~# wipefs /dev/loop0
DEVICE OFFSET  TYPE  UUID                                 LABEL
loop0  0x10040 btrfs 3bc1ff61-0e52-4189-bfce-26b54720851f
root@GL-BE3600:~# losetup -d /dev/loop0
root@GL-BE3600:~# rm test
Tested firmware versions:
Version: 4.7.1
Firmware Type: release1
Update Time: 2025-03-07 09:22:05 (UTC+00:00)
OpenWrt Version: OpenWrt 23.05-SNAPSHOT r0-3601c2a49
Kernel Version: 5.4.213
Version: 4.7.2
Firmware Type: release4
Update Time: 2025-05-29 03:27:03 (UTC+00:00)
Version: 4.7.3
Update Time: 2025-06-03 05:22:02 (UTC+00:00)
Will try to reproduce the issue in Slate 7 with v4.7.3, thanks for the troubleshooting.
R&D team has conducted depth investigations:
If the firmware enables to support the file system btrfs, flash will be used as memory when the memory is full.
Fast reading and writing will lead to the flash reduce its life.
In view of this situation, I think we would not support this in the subsequent firmware.
If you need to use this file system, please install the v4.7.1 firmware.
Truly sorry.
Thanks for looking into it!
Are you talking about swap? As far as I can see, there’s no swap configured on the slate 7:
# free
              total        used        free      shared  buff/cache   available
Mem:         936700      230796      576016        1744      129888      654176
Swap:             0           0           0
# cat /proc/swaps
Filename                                Type            Size    Used    Priority
# grep -i swap /proc/meminfo
SwapCached:            0 kB
SwapTotal:             0 kB
SwapFree:              0 kB
Yes, this refers to swap.
According to the debugging from software R&D, when testing this file system btrfs can only pass if CONFIG_SWAP is enabled; if CONFIG_SWAP is not enabled, there will be many problems with btrfs.
Once CONFIG_SWAP is enabled, when the physical RAM is full, swap will be used from flash, which may reduce the life of the flash.
Combined with the evaluation with hardware R&D, this file system would not be supported in standard firmware for now. Sorry.
@adduxa Buy or build a NAS if you need a NAS. You will get much better performance out of it than trying to shove it onto a router. You will be much happier in the long run.
Perhaps zram-swap could be used instead … it doesn’t write to the flash.
However, once the btrfs file system is enabled to support, the cache will inevitably be written to the flash when the RAM is full. It may have nothing to do with zram-swap or swap.
True, I just figured I’d mention the possibility because I’ve been surprised that GLi doesn’t turn it on by default… I’ve been using zram-swap on some devices because I run Tailscale on them which takes a lot of memory :slight_smile:
Hi bruce, are you saying that swapfile configuration is possible on v4.7.1 firmware?
Yep, only in v4.7.1
I may be mixing things up, but does this also apply to fstab settings? For example, adding an external drive with a swap partition and configuring fstab with:
fstab.@global[0].anon_swap='1'
fstab.@global[0].auto_swap='1'
Is this also disabled?
Will ask R&D guys to check, please hold on.
The swap is disabled in the kernel, cannot be enabled elsewhere. According to the manufacturer's explanation, it is because it destroys the nand flash memory. Although the swap could be on an external disk, or perhaps in memory via the zram-swap system and then it would not cause any problems. Because of this, many plugins are broken, since swap is needed for many things. It is also a bit strange that, for example, they are thinking about introducing docker. Little memory without swap and run docker ? It is not a very good idea.
Because of these, btrfs does not work, docker may be useless, zram-swap does not work, xfs does not work. Etc. Exactly those things do not work that the owner takes for granted due to the openwrt system.
Those settings probably would not work, since btfs and swap are not support in kernel.
If you want to use btfs or swap, please install the v4.8.1 firmware (test/debug) for Slate7.
So I can choose between btrfs and swap running on 4.8.1, and nfs server running on 4.8.4. Is it possible to make a version that works with everything at the same time? It's not difficult, actually. Swap should be enabled in the stable release at the kernel level, and everything would be solved. There is no real reason to disable swap, since only those who know what they are doing would use it. In their current form, these tools are misleading exactly those who choose OpenWRT because of these features. For example, it deceived me. When I bought it, I was happy with it. Now I would rather talk everyone away from it.
