Hello everybody, whom can I contact to be part of the beta test for the Slate 7 GL-BE3600?
As soon as there will be a beta, it will be announced here and on the website.
Currently there is no beta yet.
I am also interested in beta testing this device. Can you reveal whether the SoC will be from Mediatek or Qualcomm?
im so happy a new travel router is coming, the release is plan for january 2025?!
when are we gonna get a little teasing on the upcoming slate ?
That’s fine , except for the Philips hue I never really use rj45. usually when you buy this kind of router it’s for the WiFi
Hey. Quick question. Currenlty I'm owning a Beryl AX (GL-MT3000). I just ordered the Slate 7 (GL-BE3600). Is there a way to transfer the configuration from Beryl AX to Slate 7, or it's better to start from scratch?
Thanks,
B.
Better to start from scratch, the configs are not 100% compatible.
