Slate 7 Lock Out
I think I'm locked out? It says I still have 2 devices connected to the router via 2.4ghz mlo, but it won't let me turn it off or reset the firmware, etc
I want to know what operations you performed? What was the result? Can you send a screenshot of the error?
What devices are connected to the Slate 7? What WiFi are they connected to?
I forget the exact order, but I was testing my new cm5 sbc on speedtest.net. Prior to that test I was hitting around 18mbps, then I was getting 2mbps. I decided to try and tinker and tried the MLO option, not realizing I could lock myself out. BOOM. It happened. But fret not, this story has a firmware fix I found in the docs shortly after posting here
I had a working cm5 connected via wifi and ethernet and my phone connected via wifi
Yes, you can also solve the problem by pressing and holding the reset button on the side of the device for 8 seconds and then releasing it to restore the device to factory settings.
I just want to confirm how to reproduce the problem.
Thanks for your reply.
